Go to Post It's a bird! It's a plane! It's SUPER-TUBE! - dlavery [more]
Unread 09-01-2011, 02:59
stinstin stinstin is offline
VP of Systems Engineering
FRC #0948 (NRG - Newport Robotics Group)
stinstin is an unknown quantity at this point
2011 Veteran Classmate Low Disk Space Errors
Hi all, I saw one other post that mentioned this but did not see a thread about it.
We just reimaged our 2010 classmate with the 2011 Windows 7 image and installed the classmate update and the driver station update. The whole install process ran smoothly; however, I'm seeing some errors with the paging file... it appears to be only about 859 MB when the recommended size is 1522 MB. The classmate has 1 GB of RAM.
The problem is we have yet to install LabView and some of the other software, but we are already down to under 4 MB of available disk space, generating a low disk space error. Also of note is that the hardware indicates that it has a 16 GB disk, but the size of the drive showing in windows explorer is only 9.79 GB... seems like an awfully large discrepancy! I would expect it to be around 14 or 15 GB.
Is anyone else experiencing the same problem?
Does anyone know why this is occuring and if there is any way around it? I can't see this setup as being very usable the way it is now.
Thanks!
Unread 09-01-2011, 16:38
isaacdl isaacdl is offline
I have a white hat..it's just dirty
AKA: Isaac Dontje Lindell
FRC #3018 (Nordic Storm)
isaacdl is an unknown quantity at this point
Re: 2011 Veteran Classmate Low Disk Space Errors
We're also having this problem. Less than a gig of space left, and we still need to install Netbeans, the JDK, and the SunspotFRC SDK.
The extra disk space is taken up by a recovery partition that's more than 5 gigs. I'm not sure why that's necessary, since we have the restoration keys.
Also, does anyone know where we should download the stuff we need for Java developement? I could download the JDK and Netbeans from the Netbeans site, but I haven't a clue where to get SunSpot.
I'm assuming the image to reimage the cRio is included somehow in that stuff? Right now when we try to reimage, the Imaging Tool says it can't find any images.
Unread 09-01-2011, 18:12
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
I'd suggest going into Programs and Features in the Control Panel. There, if you click on Turn Windows features on or off, you can try turning off Games, Windows DVD Maker, Windows Media Player, etc. in order to save disk space.
Disabling hibernation and System Restore can reduce disk usage, but you will lose the advantages that they provide.
Also try running Disk Cleanup and maybe CCleaner.
I'm curious to know how much that helps you out.
Unread 09-01-2011, 20:24
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
I have noticed a SD card reader on the right side of the Vet Classmate. That could be used to expand some space.
Unread 10-01-2011, 01:54
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Please see my post here.
http://www.chiefdelphi.com/forums/sh...ad.php?t=88640
Eric Haskins KC9JVH
Unread 10-01-2011, 17:42
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
There is a stupid 5 GB recovery partition added by the imager. It would be useful to remove that and expand the Windows partition.
We should demand that FIRST sends us new Solid State drives...
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 11-01-2011, 06:34
Baconfly Baconfly is offline
AKA: Tylor
FRC #3330
Baconfly is an unknown quantity at this point
My thoughts. My thoughts exactly.
Unread 11-01-2011, 11:01
The link above works perfectly. Confirmed by 3 people so far. Also, removing Open Office will clear up some good space.
Software Engineer
