Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Unread 09-01-2011, 18:01
MBunzel MBunzel is offline
FRC #3238
MBunzel is an unknown quantity at this point
<R45> maximum amount of motors
are you aloud to have 4 CIM motors and 4 BaneBots motors or a combination of both that would be equal or grater than 4? ive read this rule many times and am still baffled by it. help would be appreciated!
Unread 09-01-2011, 18:05
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: <R45> maximum amount of motors
I'm going to be perfectly blunt and say I don't believe you have read that rule in its entirety.
R45 C and D answer the question.
C. one or two additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to four, and no more, 2½” CIM motors can be used on the ROBOT.
D. up to four, in any combination, of the BaneBots motors provided in the KOP (RS-775, RS-550, RS-540, RS-395),
I read, and believe the GDC mean, up to 4 cims, and up to 4 BameBots.
- Arizona North
Unread 09-01-2011, 20:34
FRC #3238
ok, thanks i did read those parts and what you said is what i thought, i just wanted someone else's thoughts on it
Unread 09-01-2011, 21:55
GEARmaster08's Avatar
GEARmaster08 GEARmaster08 is offline
FRC #0876
GEARmaster08 is an unknown quantity at this point
So are the F-P Motors in the BaneBot Category of Motors? Or how many of them can we have?
Unread 09-01-2011, 21:56
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
No, an FP is an FP. You can use the one that came in the KOP.
Unread 09-01-2011, 22:25
FRC #0876
So one and only one FP can be used?
Unread 09-01-2011, 22:28
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
yes...
Unread 10-01-2011, 09:55
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
On a more comical note, something tells me we're going to see a 8-motor drive train this year that has 4 CIMs and 4 BB-550s.
Imagine the pamphlet for such a drive train...
Blazing around the field with 2200 watts of powa!
Able to suck a FRC battery dry in 0.66 seconds!
20 ft/s!
GitHub
Unread 10-01-2011, 11:02
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
20 ft/s!
How did you get access to 1712's promotional materials already?
Unread 10-01-2011, 11:18
ebarker's Avatar
ebarker ebarker is online now
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
In terms of raw power, why would you choose a 550 over a 775 ?
In terms of durability, is the 775 better than a 550 ?
Peak efficiency data only is listed below, measurements at 12 VDC.
RS-775 - 119W, 11360 RPM, 12.5 A, 14.2 oz-in
RS-550 - 99W, 17100 RPM, 10,91 A, 7.9 oz-in
RS-540 - 49W, 14840 RPM, 5.85 A, 4.5 oz-in
RS-395 - 25W, 13110 RMP, 2.74 A, 2.6 oz-in
Ed Barker
