| Thread Tools |
Rating:
Display Modes |
2011 compressor
Veteran team needs a compressor.
Where do I get a new compressor? The pneumatics manual lists the provider but I can't find them listed in any link. Bruce |
Re: 2011 compressor
The Viair 090C Air Compressor is popular with off roaders. A simple Google search will reveal many different places to purchase one.
such as: http://www.knowwhere2jeep.com/catalog/product_info.php?manufacturers_id=318&products_id= 10990 http://www.rjroffroad.com/viair-090c...-pr-17608.html |
Re: 2011 compressor
Try 4wheelsonline.com they have it for $59.63 delivered
Re: 2011 compressor
Does anyone have any experience with these new compressors?
Re: 2011 compressor
And how do these compressors compare to the old ones?
Re: 2011 compressor
Re: 2011 compressor
The specs are much better on the new ones. 1.3 cfm versus 0.8 cfm, looking at the spec sheets for both they're consistently better on the new one.
http://www.gd-thomas.com/product.aspx?id=12084&tp=p http://www.viaircorp.com/OffRoad/90C.html Edit: Yes, they're legal. <R69> Last edited by James Tonthat : 10-01-2011 at 01:29. |
#8
Re: 2011 compressor
Re: 2011 compressor
I haven't had experience with the new one, but here's a spec comparison:
Viair 090C 90 Series Air Compressor *12-Volt *Permanent Magnetic Motor *Duty Cycle: 9% @ 100 PSI *Max. Working Pressure: 120 PSI *Inline Check Valve *Amp Draw: 10 Amps *Dimensions: 6.00 L x 2.10 W x 4.30 H *Net Weight: 2.50 lbs. *1.03 CFM at 0 PSI *0.43 CFM at 90 PSI *0.34 CFM at 120 PSI Thomas Industries 405ADC38/12 *12-Volt *Amp Draw: 10.5 Amps *MAX. PSI CONT./INT. 100/100 *0.79 CFM at 0 PSI *0.41 CFM at 40 PSI *0.24 CFM at 100 PSI *Diamensions: 7.50" L x 4.25" W x 5.375" H *Motor: Shaded Pole, Thermally Protected with High Torque Start Winding *Net Weight: 5.40 lbs Huge weight savings to be sure! |
#10
Re: 2011 compressor
can someone point me to a rule which prohibits the use of a previous compressor. (ie. are we forced by a rule that requires us to use the new compressor? ) and if so..what rule?
#11
Re: 2011 compressor
The Pneumatics manual calls out that veteran teams can legally use the compressor from past years KOP. Rookie teams have been provided the newer compressor, which veteran teams can acquire and use at their own cost.
http://www.usfirst.org/uploadedFiles...s_Manual. pdf |
#12
Re: 2011 compressor
Is there no official FIRST place to purchase one of these??
Bruce |
#13
Re: 2011 compressor
Isn't it 1.03cfm on the new compressor? <R69> forbids anything more powerful than that.
#14
Re: 2011 compressor
I think some of the difference is accounted for by the Viair compressor being rated at a supply voltage of 13.8V vs the old compressor at 12V.
#15
Re: 2011 compressor
