Go to Post Mess up something important and you lose. Just like real life. - DonRotolo [more]
Unread 09-01-2011, 12:47
EricH EricH is online now
Re: Blocking enemy mini-bots?
The only legal way to block minibots is to keep their hostbots from touching the tower/base. Once they touch the base, the best you can expect is a penalty; the other option is a red card if you continue to try and hamper them.
Unread 09-01-2011, 15:25
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
So it is basically the same as last year's end-game....
Unread 09-01-2011, 15:57
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Ryan_Davis is an unknown quantity at this point
Originally Posted by rutzman View Post
10 penalties. Each penalty is 3 points. That's a 30 point death sentence.
Even better.
"Quality means doing it right when no one is looking."
-Henry Ford
Unread 09-01-2011, 16:08
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
What if you sat down right in front of the tower between the opponent and the tower? If they're close enough they would have to expend valuable time to go around you, and if they try to push you into the tower it's not a penalty
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 09-01-2011, 16:29
Erik Huang's Avatar
Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
Originally Posted by Tiny Tim View Post
And how would you do that?
just stop the host bot from getting to the pole. get in his way, pin him, etc
Here ye, here ye! Here cometh the robot!
Unread 09-01-2011, 16:39
Robert103's Avatar
Robert103 Robert103 is offline
Rob Small
FRC #0103 (Cybersonics)
Team Role: Scout
Robert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to behold
Send a message via AIM to Robert103
It's within the rules to block another alliance from getting to their tower, so long as that bot isn't touching their tower. You would only need to keep them at a distance and tangle them up long enough to prevent their minibot from having time to reach the top. Remember, endgame this year is only 10 seconds, so even by delaying them for a couple seconds, at the very least they would place lower in the race, possibly not at all. It is important to know when to back off though, because violation of G24 is a red card.
Unread 09-01-2011, 17:11
Erik Huang's Avatar
Originally Posted by nighterfighter View Post
It is?
So that means that I couldn't pin another robot against a wall for 5 seconds during the end of the game, thus preventing them from having enough time to get to, and line up with, the tower?
2 things; if your alliance partner doesn't have a minibot, can you pin the opponent for 5 seconds, back off, then have your alliance partner pin immediately after? is the pinning rule only for one robot or the whole alliance?
also, since there are 4 poles, let's say the first three to the top were from your alliance; is that even possible and if so, would that mean 65 points?
Unread 09-01-2011, 17:18
GaryVoshol's Avatar
Cogito ergo arbitro
Each alliance "owns" two of the poles. You can only touch and score on your own pole.
(since 2004)
Unread 09-01-2011, 21:33
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
I saw the thing about each alliance only having two towers, but I didn't see it specified as to which two towers they are.
Which two towers belong to the red alliance? Where is that specified in the manual?
Thanks!
Unread 09-01-2011, 21:47
Robert103's Avatar
Rob Small
Team Role: Scout
Section 2.2.5 in The Arena:
TOWERS are located near the mid-field end of each LANE and are owned by the ALLIANCE associated with the LANE in which it is located (i.e. the TOWER intersecting the red LANE is owned by the red ALLIANCE).
Unread 13-01-2011, 12:48
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
OFF-Topic:
Is anyone else bothered by the name of the thread. Since when do we refer to our opponent's as enemies?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 13-01-2011, 12:57
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Originally Posted by Jimmy Nichols View Post
OFF-Topic:
Is anyone else bothered by the name of the thread. Since we do we refer to our opponent's as enemies?
Enemy can be defined as an adversary or opponent.
So i guess you could say "we" do that when "we" use synonyms.
Unread 13-01-2011, 14:17
Mentor,QCR Planning
So i guess you could say we do that when we use synonyms.
We discourage our students from using that term. In our minds we see that term as derogatory. Just something that we do with our students, not saying it is right or wrong.
From Websters.com
Definition of ENEMY
1: one that is antagonistic to another; especially : one seeking to injure, overthrow, or confound an opponent
2: something harmful or deadly <alcohol was his greatest enemy>
3a : a military adversary b : a hostile unit or force
Unread 13-01-2011, 14:41
royal robotics's Avatar
royal robotics royal robotics is offline
FRC #3359
royal robotics can only hope to improve
off topic!!!!!!!!
thx all this made my day so much brighter
Unread 13-01-2011, 15:18
I've always told people that other FRC teams are not our enemies. They are our rivals. We don't work to make them lose. We work to make us better.
