Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 09-01-2011, 19:43
pathogen4815's Avatar
pathogen4815 pathogen4815 is offline
There is no spoon
AKA: Tucker Baumgartner
FRC #1318 (Issaquah Robotics Society [IRS])
pathogen4815 is an unknown quantity at this point
Building Specifics for Minibots
Hey this is President of Team 1318 in Washington, while reading the rules on mini bots and parts you can and cannot use to build them. It seems that your robot is required, according to the wording of the list, to have a 12v battery but nothing else. It is stated in <R92> that while you may have up to two motors or up to 1 motor controller, you must have exactly one battery, regardless of if you need it or not. So i would like some clarification if any on if the battery is neccesary, and also as a side question, does it say in the rules anywhere whether the minibot must....
A: be touching the poll
B: stay at the top after hitting the sensor
Any help would be much appreciated!
Unread 09-01-2011, 19:55
Happy Birthday! EricH EricH is offline
Re: Building Specifics for Minibots
What escaped you was that that list was the allowed parts. You could try having a spring that was wound up and released by the hostbot to send the minibot upwards.
To answer your questions:
A) No, BUT if you're thinking of catapulting, you need to make sure that there is -100% chance of anything going wrong. That's right, negative one hundred percent. It's a serious safety issue, both for the launcher and the projectile. I suspect that the answer to this question will become "don't do it" by next week via Q&A, if it isn't dealt with in Update #1.
B) They weren't clear, but apparently, once tripped, the sensors stay tripped. So I don't think so. That's another that will go to Q&A if Update #1 doesn't note it.
Unread 09-01-2011, 19:58
Chris is me's Avatar
AKA: Pinecone
And what escaped you is that the rule specifies exactly one battery. Not "up to one" or just "one" but "exactly one".
Unread 09-01-2011, 20:01
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
This^
Someone ask the GDC please?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 09-01-2011, 20:02
If you are using the Tetrix motors, they may only be powered by
C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)
Unread 09-01-2011, 20:05
What escaped YOU was the text at the top of the rule:
The following items are the only permitted materials for use on the MINIBOTS:
Permitted !=, repeat, != required. If you were required to use the FTC battery, regardless of whether or not the rest of your minibot had any electronics whatsoever (for example, a rubber-band-powered one with a release tripped by the hostbot), then I would lose all respect for the GDC.
Unread 09-01-2011, 20:06
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
This is getting circular. clearly it is possible to read it both ways.
Common sense would hint that the battery was meant to be optional, but our common sense has no bearing on the matter. Team update #1 or the Q&A forum will firmly plant this discussion on either side of the fence. any further discussion is purely speculative.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 09-01-2011, 20:07
There is no spoon
thanks, and no, we were not thinking exactly of making projectiles, we just dont want a battery on our minibot if it doesnt require one though, if they require batteries to be on them, that defeats the purpose. There are other ways to get to the top of the pole without wheels and motors
Unread 09-01-2011, 20:25
Basel A's Avatar
AKA: @BaselThe2nd
If you substitute the battery into the overall rule you get this:
Exactly one 12V rechargeable NiMH battery pack (and other items) are the only permitted materials for use on the MINIBOTS
This implies that exactly zero batteries is not a permitted material.
I believe that the interpretation you are suggesting is the intended one, but the rules of grammar disagree with you.
-Paul Copioli
Unread 09-01-2011, 20:39
578robotsrock's Avatar
578robotsrock 578robotsrock is offline
I belive robots rock!
AKA: Erich
FRC #0578 (Red Raider Robotics)
578robotsrock is on a distinguished road
I hope they don't require you to have a battery. Seem kinda limiting for catapult launch designs
I BELIEVE THAT ROBOTS ROCK
Unread 09-01-2011, 20:59
If the GDC is requiring a battery, a particular battery, a battery that many teams either don't have quick access to or really don't want to have quick access to, then IMO they are no longer evil geniuses. I refrain from posting publicly what replaces "geniuses", but I'm sure you can come up with something.
If that is their intent, then I am certain that much noise will be made on the subject by anybody who does not use electronics on the Minibot. (Disregarding the noise being made already by those who want to use another similar product line, too.)
BTW, catapult launches fall under safety. See what I posted earlier in this thread.
Unread 09-01-2011, 22:11
Basel A's Avatar
AKA: @BaselThe2nd
Oh, I totally agree, but as the rule stands, I believe it does require a battery on the minibot, should you have one.
-Paul Copioli
Unread 09-01-2011, 22:24
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
I think they will probably require us to climb the pole
which i see as an idea from the people at cirque to make the game more watchable. (kinda a combination of cirque gymnastics and first robots)
Unread 09-01-2011, 22:47
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Maybe that's the idea. A heavier robot would be harder to launch up, thus teams can't simply shoot a piece of fin-stabilized piece of aluminum box tube at the trigger. that would be a hazard, not a miniature robot.
NOTE: I am aware that this situation is a bit extreme, but it illustrates the point.
Unread 09-01-2011, 22:50
Yep...but you'd think that it'd be easier to say, thou shalt not launch, catapult, throw, shoot, or otherwise propel a projectile, minibot, or other device at the target, unless it be affixed to the post.
