Go to Post It is great to see your friends and other teams succeed. - Bob Steele [more]
Unread 09-01-2011, 22:34
Re: capping the tower
Originally Posted by lineskier View Post
Right, but the action took place during teleop, and this is the big question I have, if you do something during telelop can you be penalized for it during the end game.
If I pin your robot at the end of teleop, can the penalty be called in the endgame?
If you do something during teleop and you can't be called for that action in the endgame, boy will there be a lot of pins when the lights start flashing.
It's a deliberate action taken to prevent a minibot from climbing. The rule does not say, In the End Game, you can't interfere with deployment/climbing. It says, You can't interfere, with no time limit given. So if I slam an Ubertube over your post's target autonomously, and it interferes with minibot deployment (which it probably will), and I don't get a red card, you're going to be in the question box explaining to the ref that you couldn't deploy because I slammed an Ubertube over your target. (In that case, I'd also get a penalty. But I might view the penalty as minor compared to the race points.)
Deliberate interference=red card.
Unread 09-01-2011, 22:59
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
RE: SteveGpage. Human player may only offer robot a tube via the designated slot. It can't be tossed into the arena over the player station.
Unread 09-01-2011, 23:01
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Read the rest of the post.
1) Field reset will want to do mean things to you. They have to remove the tubes.
I understand where you're coming from, and I know that the volunteers put in a lot of work at competitions (I've been one of them), but if there is are no rules specifically saying you can't do something, and there is not an update to change that rule, it really doesn't matter what the field reset people think or not. My team is not going to design a robot based on what the field reset people think about what work will be required of them, we are going to design it to win the competition within the spirit and written word of the rules.
Obviously safety does play a big factor into this kind of thing, but if this is foreseen an update should clarify it if the GDC does indeed to believe it to be a safety issue. Otherwise the field reset people should have a ladder.
Also, I am not agreeing nor disagreeing with this idea (which I do think is a good idea, if it proves legal) but discussing this specific point.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm tired of quoting the manual for today so all I will say is "Try again".
Unread 09-01-2011, 23:05
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
RTFM! Read the FIRST manual!
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2016: Greater DC, Central MD, Chesapeake District Championships, Championships
Unread 09-01-2011, 23:14
SteveGPage's Avatar
AKA: Steve
See <G57>
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Haha. thanks for clarifying, that was awesome.
Unread 09-01-2011, 23:16
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Eric was a volunteer. Field reset people are volunteers. You were a volunteer. The head ref is a volunteer. We are all humans. We all read the rules, we all interpret the rules. I'm with Eric. I don't see this as being legal. And I also see it as making the field reset people mad. Who aren't exactly going to be willing to give you a sort bit longer to mess with your robot, if you're the reason they have to wrestle this tube off the tower every match.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 09-01-2011, 23:29
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
<G48>?
Strategies aimed at the... entanglement of... MINIBOTS... are not allowed... Violation: PENALTY, plus potential... YELLOW CARD
Unread 09-01-2011, 23:38
mwtidd's Avatar
AKA: mike
Originally Posted by PAR_WIG1350 View Post
<G48>?
note the title of the section: "Robot-Robot Interaction"
*Section 3.1.9 GO 319!
Unread 09-01-2011, 23:42
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Another issue here is the definition of deployment "the act of positioning a minibot on the tower"
Well, if interfering with deployment could be considered as interfering from a robot getting in position to position the minibot on the tower.
Unread 10-01-2011, 00:16
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
Just an observation...
Legal or not, the tower for your opponents team is not the closest to the feeder, but the farthest. The plausibility of accurately throwing an innertube that far and that high seems doubtful.
As to the rule, I seriously doubt that they would like it if you stuck an innertube over a <10ft high pole. getting it off would be a nightmare. That being said, as previously mentioned, the rule <G48> is under robot-robot interactions, not human-robot. As much as I would like it to, that doesn't seem to apply.
HOWEVER,
<G24> The opposing ALLIANCE may not interfere with the DEPLOYMENT or climbing of a MINIBOT. Violation: RED CARD
Even though this is under the end game section, in the blue box, it clarifies that
Interference by an ALLIANCE refers to any action taken by that ALLIANCE that results in disruption of the MINIBOT’s progress
which does not stipulate a time period. So my overall guess is no.
Unread 10-01-2011, 06:17
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
There's a little something called sportsmanship and Gracious Professionalism. While they may not be official rules, they are a core part of the game.
The intent of the rules is to prevent interference to minibots attempting to climb the tower.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 10-01-2011, 07:56
GaryVoshol's Avatar
Cogito ergo arbitro
Rules <G18> to <G25> apply only to the End Game. That includes the box explaining <G24>.
Pinning <G50> is in the Robot-to-Robot interaction rules section; it applies the entire match.
The only thing that could vaguely apply here is the "strategy aimed at ... entanglement" in <G48>, and then only if you consider the game piece to be an extension of the robot. The use of game pieces in <G23> and <G24> do not necessarily consider them to be extensions of the robot. Those rules also prohibit interference by thrown game pieces. Since <G48> is a robot-to-robot rule, it would not cover thrown pieces - good luck throwing them that far.
I would consider this to be a legal (although not fair) strategy, unless the GDC changes a rule or gives a Q&A response that basically says, "No, you can't do it; the rules say so."
(since 2004)
Unread 10-01-2011, 09:55
mwtidd's Avatar
AKA: mike
The "fairness" of almost every innovative bot is debated almost every year.
Take 469 in 2010 as the prime example.
When the box is broken some of the greatest innovations occur.
