Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Unread 09-01-2011, 23:55
bakejame's Avatar
bakejame bakejame is offline
FRC #2993
bakejame has a spectacular aura aboutbakejame has a spectacular aura aboutbakejame has a spectacular aura about
Re: rack and pinion supplier
Originally Posted by zebrabots View Post
does any one know a good supplier for a rack and pinion set. meaning the sprocket and the rack. i was thinking 80/20 may have something, but I am having a hard time locating it.
Something else you might consider is using the Gates belt system. All you have to do is design something to clamp onto the belt and it would work very similar to a rack and pinion, but it would probably weigh less. Just a thought.
Unread 10-01-2011, 13:44
Best Available Data
FRC #1778 (Chill Out!)
You can also just drill & countersink holes and run a sprocket in them.
(whole robot)
