Go to Post "Yes, I'd like to Super Size my speed controller combo and add a jumbo distribution block, please." "You want fries with that?" - Travis Hoffman [more]
Unread 09-01-2011, 22:05
Jedward45 Jedward45 is offline
FRC #2220
Jedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant future
Combining Motors
Im wondering if anybody knows how to put a CIM and a fisherprice motor in the same gear box. Im assuming that some alterations must be made to accommodate the different rpms.
Thanks!
Unread 09-01-2011, 22:41
Re: Combining Motors
Run the FP through an AndyMark planetary and you should have no problems.
http://www.andymark.com/SearchResults.asp?Cat=182 I'm just not certain which one to use...
I'm not quite certain what happens with the new FP motor, but that's a start.
Unread 09-01-2011, 22:48
FRC #2220
how exactly do these planetary gearboxes function? also, what new FP motors? were they changed?
Unread 09-01-2011, 23:06
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
google "planetary gear animation"
Ed Barker
Unread 09-01-2011, 23:10
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Planetary gearboxes work by having a layer of a certain number of gears around a shaft (coming from your motor). This set of 3 or 4 gears rotates in conjunction with a inside gear outside of the other set of gears.
I know I am horrible at explaining this, but just look at this picture:
and this one:
The second picture is a regular drill gearbox.
I hope this helps!
Unread 09-01-2011, 23:16
Chris is me's Avatar
AKA: Pinecone
That being said, you probably won't be combining CIMs and FPs this year, since there is one FP and for 95% of teams they should have 4 CIMs in their drive.
Unread 10-01-2011, 00:13
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Are you limited in the number of FP motors you can use? The RS motors can only be used in a max total amount of 4. You can only use 4 CIMs, But they don't limit the number of FP motors used.
You only get one in the KOP, but you can buy more.
-T
Unread 10-01-2011, 00:21
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
you can only buy more CIMs because the rules say so.
The rules say no such thing about FPs.
Thus, only the single fisher price motor provided may be used.
Sorry to deliver the bad news, I wish we had more also. on the other hand, the RS-775 has respectable specifications.
