Go to Post Maybe there's some reason that makes it not that simple... - Cory [more]
Unread 10-01-2011, 00:35
Nishant Nishant is offline
FRC #0008 (Boeing and Palo Alto High School Robotics)
Team Role: Electrical
Nishant is an unknown quantity at this point
Minibot Battery
I was wondering about the wording of the Minibot rules:
The FRC manual sec4:
R92"exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)"
But
"No more than one HiTechnic DC motor controllers"
Since FIRST did not choose to say "No more than one battery", are you required to have the 2lb battery on your Minibot?
Thanks,
Nishant
Unread 10-01-2011, 10:24
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Minibot Battery
I interrupt that rule to mean that all Minibots must have the battery on board. However that is something to ask the GDC for an official ruling on the Q&A.
With that being said, building a Minibot that climbs the pole with out a battery would be very difficult. Not impossible, but it is far more likely that all Minibots will use a motor and battery to climb the pole.
A solution that uses only the bending of material, surgical tubing or rubber bands as sources for stored potential energy would be very impressive.
Unread 10-01-2011, 11:01
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Minibot Battery
*note, the following statement is my opinion. it is not based on any sort of solid ground.*
I assume that the GDC wants anyone who plans on building a minibot to use some sort of motor or electric devices to climb to the top. Although, just because you have a battery, doesn't mean you need to use it.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 11-01-2011, 22:16
Re: Minibot Battery
FIRST has made a mandate for the use of the battery:
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). Violation: The TOWER on which the MINIBOT is DEPLOYED is disabled. If the MINIBOT is not deployed DEPLOYED on something other than a TOWER, then the ALLIANCE’Ss
(Team Update 1)
Unread 11-01-2011, 22:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Minibot Battery
Yeah, we wondered about that funny wording, but now in light of Team Update #1 it makes sense.
Unread 12-01-2011, 00:20
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Minibot Battery
*sigh*, no surgical tubing wind up toys allowed.
Go REX!!!
Unread 13-01-2011, 19:43
OmerSD OmerSD is offline
FRC #1690
Team Role: CAD
OmerSD is an unknown quantity at this point
Re: Minibot Battery
Could anyone please upload or link to the battery's specifications?
I've tried looking the part number (PN W739057) on google and browsed through several threads here on CD, but found nothing.
By Specification I also mean dimensions and weight.
Thanks in advance.
Unread 13-01-2011, 19:56
Bmarquez Bmarquez is offline
FRC #3143 (Extreme Exotic Fire Breathing Rubber Duckies)
Bmarquez is an unknown quantity at this point
Re: Minibot Battery
PN W739057 does not exist as a part for one reason, PN is a designation by FIRST in their own organization
a search for W739057 however turns up the component in the tetrix kit Battery
Unread 13-01-2011, 20:11
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Minibot Battery
http://shop.pitsco.com/store/detail....&c=0&t=0 &l=0
Don't have dimension or weight though.
http://www.all-battery.com/rectangul...ightrobot.aspx
This is a similar battery but 3.3 times the capacity. It's also a 10-cell. So the dimensions should be similar but probably heavy than the 3000mAH pitsco battery.
Actually, we have a few of the 3000mAH batteries from our FTC team. I will measure and weigh them tonight.
Unread 13-01-2011, 23:39
Re: Minibot Battery
This post has numbers for the weight. The size is ten upright C-size cells in a 2x5 array encased in thick heat-shrink material.
Unread 14-01-2011, 00:10
mikets's Avatar
Software Engineer
Re: Minibot Battery
Yep, I weighed the motor and the battery pack tonight and they came out very close to the numbers in the other post:
Motor: 0.469 lb
Battery: 1.320 lb
Unread 14-01-2011, 20:18
FRC #1690
Team Role: CAD
Re: Minibot Battery
thanks a lot for replying! this sure will be helpful with the minibot design.
everyone's enjoying the build season I hope
Unread 17-01-2011, 09:02
Re: Minibot Battery
PN is an industry abbreviation for Part Number.
