Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 10-01-2011, 00:00
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Post Minibots Scoring after Teleop is 'Over'
Will the minibots have an extra ten seconds to score after the match is over, such as how there was a 10 second period in Breakaway where scored balls would still be counted? Meaning that even after the buzzer sounds, there is still 10 seconds to allow the minibots to finish climbing the pole?
Unread 10-01-2011, 00:48
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Re: Minibots Scoring after Teleop is 'Over'
I think this has been asked before, so you may want to try a search next time. However:
According to the definitions in the manual:
<g02>
The AUTONOMOUS PERIOD ends when the ARENA timer displays zero seconds. The MATCH ends if all TOWERS are TRIGGERED or when the ARENA timer displays zero seconds, whichever comes first.
(emphasis mine)
and
<g62>
The AUTONOMOUS SCORE is tabulated at the conclusion of the AUTONOMOUS PERIOD; all other scores are tabulated at the conclusion of the MATCH.
(emphasis mine)
And the end of the MATCH is when the arena timer is 0, so no, they need to finish in the game time, not the following 10 seconds.
Unread 10-01-2011, 00:54
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I agree about searching, but how do you reconcile this with <G68>?
Unread 10-01-2011, 01:15
no team (Volunteer)
You are right, Bill_b, I had not noticed that. But my bet (and this should go through the Q&A) is that they will say that "objects" does not include robots. My guess is the intent of this rule is for the tubes still settling down on the pegs or the rule could be left over from last year.
Unread 10-01-2011, 01:48
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
I would agree with techalex. Worth asking in the Q&A though.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 10-01-2011, 08:42
GaryVoshol's Avatar
Cogito ergo arbitro
I suspect this will be resolved by how the field and the elements are controlled, not by whatever the rules say. From the blue box in <G02>:
This chase sequence will continue until a MINIBOT TRIGGERS the TARGET, or time expires, whichever comes first. If a MINIBOT TRIGGERS the TARGET within the set time period, the TARGET light will illuminate to indicate in which place the MINIBOT finished.
I would imagine that when the clock hits zero, the electronics that shut off the chase sequence will also shut off the scoring opportunity.
(since 2004)
Unread 10-01-2011, 09:45
dodar's Avatar
dodar dodar is online now
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Actually I do believe the rule last year where if a game piece or object is in motion when the timer hits 0, they have 10 seconds to do whatever or until they come to rest like the soccer balls last year. I don't think the field will be able to shut down the mini-bots so if you launch at anytime in the final 10 seconds of the game, you can have, essentially, up to 20 seconds for that min-bot to score a minimum of 10 points.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 10-01-2011, 10:08
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
That's how some of my team-members view it as, but I think that due to <G02>, the minibots will only have the ten seconds to complete the endgame.
(emphasis mine)
Unread 10-01-2011, 10:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This is obviously a perfect Q&A question, but I'm suspecting G68 means that the minibots will have an extra 10 seconds after the end of the match to trigger the tower. There's ample precedent for the GDC letting robots continue moving after the match. In 2007, some pneumatic lifting ramp bots were specifically designed to start lifting 1 sec before the match ended, because the stored air would finish the lift before 10 seconds were up. So I suspect the GDC is going to give the additional 10 seconds and make sure the field is programmed to allow for it.
Unread 10-01-2011, 11:16
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
For those wondering, <G68> states Scores will be assessed when the MATCH ends and all objects in motion come to rest, or 10 seconds elapses, whichever comes first. The confusing thing is that in <G02>, it doesn't specify what the 'set time period' is, yet it sounds, to me at least, that the time period is the final ten seconds of the end game, before the 2 minute 15 second match 'ends.'
Unread 10-01-2011, 11:48
GaryVoshol's Avatar
Cogito ergo arbitro
Yes, that's the way it was last year, and that's the way those electronics were set up. There was a yellow light above the driver station that stayed on 10 seconds after the timer hit zero, and the ball counter (and DOGMA counter) was active during that 10 seconds.
But notice how the flashing lights are set up this year. The part I quoted before says the lights are active until timer hits zero. I suspect - I don't know, but I suspect - that means the MINIBOT has to hit the trigger before the time runs out, regardless of any rule about objects in motion.
(since 2004)
