Go to Post Glitter… lots of glitter. - Andrew Schreiber [more]
Unread 10-01-2011, 11:23
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Duplicate symbol main
Hi,
Yesterday I got the cRIO up and working and flashed and whatnot and decided I should test using my own code so I loaded up WindRiver's example hello world program but when I ran it netconsole kept complaining about duplicate symbol main or something. Does anyone know why this is happening and/or has a way to run a hello world program on it?
Thanks,
Oliver
Unread 10-01-2011, 15:13
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Duplicate symbol main
Be sure that you create the robot program using one of the Downloadable Kernel Module sample programs. The only ones that work have names that start with "FRC", the others are designed to run on other platforms (not the cRIO).
Brad
Brad Miller
Robotics Resource Center
Unread 18-01-2011, 22:09
AKA: Oliver Graff
FRC #3780
thanks!! that fixed it.
Oliver
