Go to Post No one shall stand between me and my sleep. - Adam Y. [more]
Unread 10-01-2011, 11:29
TNaylor TNaylor is offline
FRC #3777 (Team Robocalypse)
TNaylor is an unknown quantity at this point
Re: Mini-bot Ideas
Originally Posted by dsmith14469 View Post
Something our team learned is that the sensor that needs to be triggered is 3 limits switches wired in series positioned around the circle. So launching an item my trigger only one switch and no the other two in which case no score.
Actually, since they are in series, actuating just one switch would disrupt the entire circuit and would be registered as a score.
Unread 10-01-2011, 11:31
Beta Version's Avatar
Beta Version Beta Version is offline
AKA: Matthew
FRC #0624 (CRyptonite)
Beta Version is on a distinguished road
Re: Mini-bot Ideas
actually, per my understanding, these switches are held between two plates. The minibot hitting the bottom plate will activate all the switches
Victor 3 Strikes again!
Underwater Bot
Paratrooper Bot
Unread 10-01-2011, 12:18
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: Mini-bot Ideas
Are the switches normally open or normally closed?
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 10-01-2011, 12:36
MechJim's Avatar
MechJim MechJim is offline
AKA: Jim Morris
FRC #3284 (Laser)
MechJim is an unknown quantity at this point
Re: Mini-bot Ideas
We were considering ideas that would not require any electrical devices for the minibot. For example, the minibot could be constructed small, lightweight, and powered by a wind up spring mechanism. As the host bot pulls away from the minibot it could release a latch that then lets the minibot shoot up the pole with stored spring power driving wheels or such. Unfortunatly, per the materials list it looks like any team wanting to power the minibot with a spring must use either rubber bands or the surgical tubing.
Am I missing anything in the rules that would prevent us from powering a minibot by stored spring energy as long as it is deemed safe?
Thanks
MechJim
Team 3284
Unread 10-01-2011, 12:39
578robotsrock's Avatar
578robotsrock 578robotsrock is offline
I belive robots rock!
AKA: Erich
FRC #0578 (Red Raider Robotics)
578robotsrock is on a distinguished road
Re: Mini-bot Ideas
I am extremely interested to see if launched mini-bots will be allowed
I BELIEVE THAT ROBOTS ROCK
Unread 10-01-2011, 12:50
pfreivald's Avatar
AKA: Patrick Freivald
Re: Mini-bot Ideas
I think that there are a lot of unknowns right now about what, exactly, is legal as far as MINIBOTs are concerned. "Climb", "deploy", and "autonomous" are all sufficiently ambiguous that there is a lot of outside the box thinking going on -- some of which will be legal in the end, some of which won't, and all of which is good stuff either way.
Well, keep in mind the material usage rules... Springs aren't allowed, although elastic deformation is possible with other materials.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 10-01-2011, 12:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Mini-bot Ideas
If you think you want to launch a minibot, PROTOTYPE IT. We did.
No really, try it. Then come back with the results. There's way too much conjecture in this thread...
GitHub
Unread 10-01-2011, 13:31
HazzardFuzzBomb's Avatar
HazzardFuzzBomb HazzardFuzzBomb is offline
Why is that smoking?
AKA: Dakota
FRC #1780 (Wolves Robotics)
HazzardFuzzBomb is an unknown quantity at this point
Re: Mini-bot Ideas
Sorry I don't have the insides of the rule so can someone post them but check out rule g20
Unread 10-01-2011, 15:27
lbl1731 lbl1731 is offline
AKA: Levi
FRC #1731 (Fresta Valley Robotics)
lbl1731 is an unknown quantity at this point
Re: Mini-bot Ideas
Has anybody else come to the conclusion that the mini-bot can be anything? I've read very carefully through the rules and theres no rule that says the mini-bot has to be deployed on the pole or at the tower. All it has to do is trigger the target. Other than obvious safety concerns, theres no rule that says we can't just launch a tennis ball across the field and hit the target. The tennis ball would be the mini-bot. Well a tennis ball isn't allowed i suppose by the mini-bot material rules. So how about throwing a FTC wheel up there? As long as it is a controlled toss it wouldn't pose much of a safety hazard. And it fits all of the rule requirements.
The GDC has to put our some more rules concerning the mini-bot and I think they will. This also explains the mysterious missing section 3.4.14....
Something to think about.
Unread 10-01-2011, 15:37
pfreivald's Avatar
Re: Mini-bot Ideas
There are too many unknowns on the MINIBOTs. I think they seriously need to define 'climb' and 'deploy'.
I suspect that when all is said and done, the MINIBOT will have to maintain continuous contact with the tower on its way up (thus "climb" and not "jump"), and DEPLOYMENT that adds vertical kinetic energy to the MINIBOT will be disallowed...
I'm not positive, but that's my suspicion.
Team 1551
I write books, too!
Unread 10-01-2011, 15:48
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Re: Mini-bot Ideas
Are you sure you read the rules carefully? I suggest you re-read rule <G20>.
Unread 10-01-2011, 16:16
AKA: Levi
Re: Mini-bot Ideas
Yeah I read that, but that says nothing about the mini-bots not being able to contact the tower above the deployment line. And as long as you propelled the mini-bot below the line, that satisfies rule <G20>.
Unread 10-01-2011, 16:38
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Mini-bot Ideas
The only thing right now that would support the minibot always having to stay on the pole is:
<G46> MINIBOTS may only be used to climb the TOWER.
Violation: YELLOW CARD
The reason i bring that rule up is because you're not climbing the tower if you're not touching it. So there's no rule so far saying you can't do that, but I can almost guarantee you that rule will be established (that you always have to stay in contact with it)
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 10-01-2011, 17:46
NinjaMonicaRox NinjaMonicaRox is offline
AKA: Monica Hnatiuk
FRC #2851 (Crevolution)
Team Role: Student
NinjaMonicaRox is on a distinguished road
Re: Mini-bot Ideas
A motorized minibot is easy to come up with. What I'm having a difficult time coming up with are ideas for a spring powered one, maybe like a mousetrap car sort of thing but I'm not sure...
Unread 10-01-2011, 17:52
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Mini-bot Ideas
Here is <G20>
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE. Violation: PENALTY for contact. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
