Go to Post If the GDC doesn't want better teams to strap components on to other robots, they should design a game that doesn't require better teams to strap components on to other robots to win. - Tom Bottiglieri [more]
Unread 09-01-2011, 19:53
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: 2011 Minibot electronics
Originally Posted by rtfgnow View Post
You can have your one way trip, I don't want the field reset team to pull out a shotgun to get our minibot down.
I meant one-way powered......after contact with the sensor, the 1/2 bridge is turned 'off' and the mini coasts downward.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 09-01-2011, 19:56
Jon236's Avatar
AKA: Jon Mittelman
Originally Posted by EricVanWyk View Post
Is it legal to have a tether wire between the robot and the minibot? Wires are allowed in R92X, but I'm not clear whether or not the sizing box in R91 precludes them.
While only the GDC can say for sure, I am assuming that tethers would be illegal because of the 12x12x12 sizing box requirement and by the usual no-entanglement rules.
Jon Mittelman
Unread 09-01-2011, 19:59
Erik,
From Section 1
MINIBOT – an autonomous vehicle designed and built to perform specific tasks when competing in the 2011 competition LogoMotion. The MINIBOT must obviously follow a design approach intended to play the 2011 FRC END GAME and must be compliant with all MINIBOT rules defined in Section 3.4.14.
And from Section 1.5
The match ends with robots deploying minibots, small electro-mechanical assemblies that are independent of the host robot, onto vertical poles.
I read those two references as not tethered. The Q&A will be the only place to get an official answer on this question.
Unread 09-01-2011, 20:01
Eric,
Thanks Al
After reading those sections, I agree with your interpretation.
Unread 09-01-2011, 20:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by JohnHorton View Post
Well, a 9v regulator would work, but that isn't listed on the components allowed.I find it kind of odd they don't allow basic electronics (resistors, caps, etc.) for the minibot. Correct me if I'm wrong.
I think a simple DC loop of Battery - Lightswitch - motor(s) - back again might be the best, as far as electronics go.
I believe their assumption was that if you are using the NXT, it drives a PWM signal out (at least, I believe that's how it drives the servo motors used in FLL). You would use that to send the duty cycle to a motor controller which in turn would actually use the 12V battery to power the motors.
Unread 09-01-2011, 20:33
ptan ptan is offline
Paul C. Tan., P.Eng.
AKA: Paul Tan
no team (Bolt Action)
ptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to behold
The allowed Tetrix motors are ordinary DC motors. You can power them directly from the 12V battery through a light switch if you wanted.
In FTC, the NXT connects to the HiTechnic motor controller which converts the I2C from the NXT brick to control an HBridge powering the DC Tetrix motors.
Coach - FTC Team 27 (now retired)
Coach - VRC Team 2027 (now retired)
Past Mentor - FRC Teams 188, 610, 1009, 2634
Unread 09-01-2011, 21:02
JohnHorton's Avatar
JohnHorton JohnHorton is offline
Shock Test Dummy
FRC #1100 (Tomahawks)
Team Role: Electrical
JohnHorton will become famous soon enough
Originally Posted by Jon236 View Post
Maybe it's time to teach the students how to make a speed controller (1/2 H-bridge....since all we want is a one-way trip (powered, at least!))
That begs the question, can we fab our own parts? I'd love to skip the NXT controller and just build an H bridge run by a flip-flop. State 0 on it would be triggered by the "launch" command from the hostbot, sending the motor forward and State 1 would be triggered by a switch on top, when the minibot hits the target, reversing the motor so that Dean Kamen won't go after my bot with a pole saw.
However, they don't list discrete components on the list. I guess that's something for the Q&A.
The tall guy in the camouflage hat.
John Horton
Unread 09-01-2011, 21:24
DonRotolo's Avatar
Back to humble
FRC #0832
My interpretation is, if it is not on the list, it is not allowed.
Well, since you can bring any number of minibots to competition, just bring one per match and let THEM figure out where to apply the pole saw! (Just kidding, of course. <G59> covers it).
<G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT once it has climbed above the DEPLOYMENT LINE.
I read <G22> as not tethered as well.
Unread 10-01-2011, 00:06
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Oh dear, tape measures
Unread 10-01-2011, 08:31
<R92> The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components,
B. no more than two motors (PN W739083),
C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)
D. No more than one HiTechnic DC motor controllers,
E. No more than one NXT controller with the Bluetooth functionality disabled,
The motor controllers are driven from the NXT outputs.
Unread 10-01-2011, 11:16
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Again what do you all think. R92 d sayes exactly 1 battery pack. Do you think that means we HAVE TO HAVE a battery??
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 10-01-2011, 11:18
Jon236's Avatar
AKA: Jon Mittelman
Bruce
Without specifying a required wiring schematic, I think that IF we want a battery, it has to be the battery they specify. But I don't read anywhere that we HAVE to have a battery.
GDC just want to make our brains hurt!
Jon Mittelman
Unread 10-01-2011, 11:27
Just a Mom Just a Mom is offline
Just a Mom
FRC #0269 (CooneyTech Robotics)
Just a Mom will become famous soon enoughJust a Mom will become famous soon enough
Does anyone else find it frustrating that we must use the FTC kit to build the mini robot? There are no FTC teams near us that I know of so the only way we can do this is to buy a kit and they are already on back order.
Unread 10-01-2011, 11:38
JohnHorton's Avatar
Shock Test Dummy
As per my understanding, you don't have to use the FTC kit, it just helps. Making the whole thing out of polycarb. or aluminium, using the 12v NiCd, and the lightswitches is possible, and a lot simpler than using the NXT and co.
John Horton
Unread 10-01-2011, 11:48
O-H
FRC #0048 (Delphi E.L.I.T.E.)
You can obtain a free FTC kit as part of the FIRST Choice program (ala carte kit of parts items that were not handed out to all teams) on www.andymark.com.
There are 1265 sets left as of 11:45 AM this morning, 1/10/11.
Be proactive - order now.
Please see http://www.andymark.com/SearchResults.asp?Cat=245 for instructions on how to login to FIRST Choice.
