Go to Post Technology is everywhere, yet the human factor is what makes an event special. - synth3tk [more]
Unread 09-01-2011, 13:15
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Banebot Motor Spec Discrepencies
So here are the motor specs listed on the sheet from Banebots in the KOP as well as the specs listed on the FIRST website
Banebots Sheet: RS-775, Free Speed: 13,000 RPM, Free Current: 1.8A , Stall Torque: 110.8 oz-in, Stall Current: 86.7A
FIRST site: RS-775, Free Speed: 7,300 RPM, Free Current: 1.1A , Stall Torque: 61.1 oz-in, Stall Current: 30A
The Banebots website has specs that match are similar to the sheet, when you take the data into account at 12V.
http://banebots.com/pc/MOTOR-BRUSH/M7-RS775-18
However the FIRST data matches what is shown for the 12V equivalent of this motor.
http://banebots.com/pc/MOTOR-BRUSH/M7-RS775-12
Anyone have any idea on what the actual specs are on these motors? Has anyone tried testing them out yet? The label on our motor is definitely for the M7-RS775-18, but I'm weary of trusting a sticker.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 09-01-2011, 13:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Banebot Motor Spec Discrepencies
I haven't investigated it yet, but can someone scan to PDF and post the green BaneBots page included in the KOP for us to compare?
Unread 09-01-2011, 15:49
banebots banebots is offline
banebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant future
Please note that the 18V version of the RS-775 was included in the KOP
Part number M7-RS775-18
link: http://banebots.com/M7-RS775-18
The data on our web site is for the motor at 18V, it nominal Voltage
The data on the green sheet is for the motor at 12V, what FIRST will use it at
We opted to donate the more powerful 18V motor because we believed it would be more useful to FIRST teams than the 12V model. The 18V motor will operate fine at 12V with reduced performance as given on the green sheet.
The label on the motor is correct, all FIRST legal motors supplied by BaneBots will have an appropriate orange label to ease inspection and reduce confusion.
Our less powerful 12V RS-775 (M7-RS775-12) IS NOT FIRST LEGAL to the best of our knowledge.
BaneBots
Unread 09-01-2011, 16:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
When will there be info (including availability) of the P80's for the 775 and the new CIM-U-LATOR?
Unread 09-01-2011, 16:45
BaneBots
Thanks for the quick and helpful response. Just for your reference, here's the spec sheet from FIRST with the incorrect information.
http://www.usfirst.org/uploadedFiles...r%20Curves.pdf
Unread 09-01-2011, 18:00
P60 with RS775, P80 with RS775 and CIM-U-LATOR should be up on the web site by the end of the week and available for order at the start of next week.
Links to data sheets for the BaneBots motors found in the KOP:
http://banebots.com/docs/M7-RS775-18-AT12V.pdf
http://banebots.com/docs/M5-RS550-12.pdf
http://banebots.com/docs/M5-RS540-12.pdf
http://banebots.com/docs/M3-RS395-12.pdf
Note the RS775 data sheet is for the 18V motor in the KOP at 12V
BaneBots
Unread 09-01-2011, 20:04
kevinhorn kevinhorn is offline
FRC #3213 (Thunder Tech)
kevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nice
Thank you, I really appreciate your attention to detail. I made graphs off of the specs on the Banebots site but knew that the 18v data was wrong for this application.
The range of power provided by the Banebots KoP motors gives more "good" options for motoring our mechanisms.
By the way I really like the RS-550-12-Backshaft. This allows us to place a 100 count encoder directly on the motor and would be a great option for next year.
Unread 09-01-2011, 21:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Be sure to check with the Q&A whether that's legal. (After all, it's a different motor with a different shaft, despite the electrical internals presumably being identical.)
Unread 10-01-2011, 00:48
Smile Re: Banebot Motor Spec Discrepencies
Tristan,
I was making a suggestion for future years. I wouldnt dream of putting a non KoP motor on a competition bot. This is a setup we use on our half size proof of concept bot. The easy encoder mounting made feedback and CAN testing much easier. The encoder resolution is crazy. It would be very nice to have easy encoder mounting available on game play motors. To see some really interesting data on the RS-550-12 connected to a 20:1 P-60 go to http://www.chiefdelphi.com/forums/sh...ad.php?t=88193
Unread 10-01-2011, 08:32
President, VEX Robotics, Inc.
I just tried to order 12 of the 775 motors on the BB web site and they said they are out of stock. Is BB holding them for the custom gearboxes? When will they be available?
Thanks for the support.
Paul
PS - I personally appreciate the decision to use the 18V version over the 12V version. These will be much better for FRC teams even at 12V.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 10-01-2011, 10:58
We had an error on our website that caused some products to incorrectly be shown as out of stock.
All four of the BaneBots KOP motors are in stock and available.
We apologize for any inconvenience
BaneBots
Unread 10-01-2011, 12:42
ttldomination's Avatar
Sunny
Can someone explain their decision for using the 775 over the 550? The specs for the 550 seem to be most similar to the FP motor from previous year. And other than a higher current pull, I don't see much of a reason to use the 775.
Thanks,
Sunny
1648: 2013-2014
5283: 2015
Unread 10-01-2011, 12:48
Jared Russell's Avatar
Taking a year (mostly) off
BaneBots
Thanks for the reply. Will the CIM-U-LATOR gearboxes come with our choice of motor already installed? If not, could you outline the procedure for installing them (trying to gauge if it is something we can do at our main shop or would need sponsor help)?
Unread 10-01-2011, 12:56
Chris is me's Avatar
AKA: Pinecone
I've heard bad things about the RS - 550's durability.
The RS - 775 looks like a powerful motor (check the data sheet) and it is designed for 18 volts, so it has a good safety factor built in.
Unread 10-01-2011, 13:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Thanks,
Sunny
The 775 maxes out at ~270W (peak speed), while the 550 is around ~250W. The 775 is also closer in terms of both speed and torque to FRC applications, meaning less reduction will be needed to utilize it effectively. This outweighs the minor differences in current draw, imo.
