Go to Post The evil Chief Delphi machine will begin to consume you and your non-robotics life thread by thread. First hand experience :D. - frcguy [more]
Unread 09-01-2011, 22:07
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
rack and pinion supplier
does any one know a good supplier for a rack and pinion set. meaning the sprocket and the rack. i was thinking 80/20 may have something, but I am having a hard time locating it.
Unread 09-01-2011, 22:18
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: rack and pinion supplier
McMasterCarr has a variety of rack and pinion combinations. The prices also seem reasonable.
http://www.mcmaster.com/#racks-and-pinions/=aitzn2
Unread 09-01-2011, 23:55
bakejame's Avatar
bakejame bakejame is offline
FRC #2993
bakejame has a spectacular aura aboutbakejame has a spectacular aura aboutbakejame has a spectacular aura about
Something else you might consider is using the Gates belt system. All you have to do is design something to clamp onto the belt and it would work very similar to a rack and pinion, but it would probably weigh less. Just a thought.
Unread 10-01-2011, 13:44
Best Available Data
FRC #1778 (Chill Out!)
You can also just drill & countersink holes and run a sprocket in them.
(whole robot)
