Go to Post Test your code and your assumptions. - ShotgunNinja [more]
  #36   Spotlight this post!
Unread 10-01-2011, 13:47
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: <R11> Dimension wrong?
Minibot deployment mechanisms could be built to help get a little more room out of this restriction because the minibot itself (The portion that detaches from the hostbot) is not considered in volume limitations.
From <R11>
For the purposes of determining compliance with the weight and volume limitations, the items listed below are NOT considered part of the ROBOT and are NOT included in the weight and volume assessment:
A. the 12V battery and its associated half of the Anderson cable quick connect/disconnect pair (including no more than 12” of cable per leg, the associated cable lugs, connecting bolts, and insulating electrical tape),
B. BUMPER assemblies (including BUMPER covers, if appropriate) that are in compliance with Rules <R07> and <R08>,
C. the OPERATOR CONSOLE, and
D. the MINIBOT.
So if we were to only touch the minibot from the back you could extend it past the 60" mark(or whatever the dimension truly is).
