Go to Post Start respecting your mentors more or they might just leave. - Eric Bareiss [more]
Unread 09-01-2011, 15:33
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
How should we wire the photoswitches?
Hi,
we just got our 2011 kit, and in that kit were three Photoswitch sensors. None of us has ever used this kind of sensors so I'd really appreciate if you could explain how it works, how we should wire it and where to.
Thanks.
Unread 10-01-2011, 14:57
Re: How should we wire the photoswitchs?
Itamar,
There is a section on the First Website under Competition Docs that explains the sensors. I believe it is under the KOP section. I just tried to log on but the site looks a little busy.
Unread 10-01-2011, 15:23
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Here is what I had downloaded from the FIRST website. Hope it helps. They are photoswitches and will give you a digital response. Follow the wiring diagrams carefully!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 10-01-2011, 15:36
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
http://usfirst.org/roboticsprograms/....aspx?id=18530
This page contains, among other things, links to the datasheets for a lot of the KOP items. I believe the sensors your referring to are the "Rockwell Automation Line Sensors":
http://www.ab.com/sensors/photoelect...eral/42ef.html
The links on the right side of the page to the catalog and installation PDF's are probably the most help... although I don't know the specific part we got in the KoP, and the checklist doesn't have a part number! Without those, I can't give too much useful information... although your questions are exactly those I know my students will be asking me!
Unread 10-01-2011, 16:29
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
The Line sensors given to us in the KOP are model: 42EF-D1MNAK-a
Unread 10-01-2011, 18:05
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
ok, so we've looked at the wiring diagrams, and I have to say, it's not helping us very much. Under the 10.8 - 30V DC Sensors, there are 6 different configurations. Does the 'Load' mean that we have to use resistors in the circuit? I'm gonna display my ignorance here - how do we wire them to the robot? Is the digital sidecar involved here?
Unread 10-01-2011, 20:35
I don't have the datasheet handy, so I'm going from memory.
DO is the "Dark Output". It is active (i.e. connected to ground) when the sensor is looking at "dark", and inactive (i.e. allowed to float) when the sensor sees "light".
LO is the "Light Output". It is active when the sensor is looking at "light", and inactive when the sensor sees "dark".
Connect ground to ground, power to +12 volts, and either LO or DO to a digital input pin on the Digital Sidecar. The input pin will read a logic 1 when the signal is inactive, and a logic 0 when it is active.
Unread 10-01-2011, 21:02
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
We need to put a resistor in series, don't we? The 9403 can withstand a 30v signal, but use at this voltage will degrade the life of the module.
The standard voltage it specs is -0.5v to 5.25v.
If possible, I'd prefer to use an inline resistor, instead of a voltage divider. At 250 micro-amps, it would take a 34k resistor to drop the voltage from 12v to about 5v.
-- Marshal Horn
Unread 10-01-2011, 21:19
It looks like the output of the sensors is just like a Banner sensor's NPN output. It supplies no power. It is effectively an on/off switch that either connects the output to ground or leaves it open. The Digital Sidecar's inputs will happily take that input without modification; it's basically what they were designed for.
Unread 10-01-2011, 21:29
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Oh, okay. That's why they gave us NPN then. Cool!
-- Marshal Horn
Unread 10-01-2011, 22:03
bakketti bakketti is offline
FRC #0443 (Freelance Robotics)
bakketti is an unknown quantity at this point
Just as a sanity check... Looking at the Wiring Diagrams for the NPN ouputs: Dark Output is the Black line and Light Output is the White line. Is that a correct statement?
Unread 11-01-2011, 14:02
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Lets be very careful with those 'line sensors' and the electrical hookup.
Some facts that we do know. The sensor will work just fine on 12 volts DC which generally means at the output (ie: LO,DO ) MAY have a voltage range from 0VDC to 12VDC. The Digital sidecar does have a 'general purpose' I/O lines which opearte in the 0VDC to 5VDC range!!!!!
That means if the sensor sources a 12VDC level you can kiss your digital sidecar goodbye as the blue smoke comes out. NO, a series resistor will only limit the current, not the voltage and either or both will kill a digital sidecar.
To be on the safe side I would use the analog sidecar to input the sensors.
I have not looked at the sensors tech sheets yet but will sure err on the side of caution.
Of course one way to find out is to look at the 'sample code' and see where the information for the sensors is read.
Unread 11-01-2011, 14:30
The sensor outputs do not source anything. They will never have a voltage greater than what they are connected to. If you connect LO or DO to the Digital Sidecar, it will either have 5 volts (when inactive) or zero volts (when active) on the output.
If you haven't looked at the documentation, you shouldn't be giving advice about how to use things.
It reads it from the Digital Sidecar DIO pins.
Unread 11-01-2011, 14:50
The light sensor outputs will provide a closure to power common or will remain open circuit. The digital side car digital inputs have pullup resistors to +5 volts. So when the sensor is open, the output will be pulled up to 5 volts through the DSC and when the sensor is closed, the output will be pulled down zero volts through the NPN transistor in the sensor. No other components are needed. The 12 volt input is required to power the emitter and other internal electronics.
Unread 11-01-2011, 21:08
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
The original question is quite direct, but to rephrase it:
What should be connected to:
1. White
2. Black
3. Blue
4. Brown.
We have read all of the Allen Bradley docs.
They seem to show that once the two bleeder resistors are in place that the unit has two leads left.
Since one is supply at 11-30 volts DC and the other must be common, there are no leads left to serve as the output.
Where and how does the output signal get connected to the CRIO I/O?
Charlie Affel,
Mentor 423
