Go to Post Not all current students are math dummies. Not all 1960's students were math geniuses either. - Clem1640 [more]
Unread 10-01-2011, 15:10
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
Re: Mecanum - use of gyro
Originally Posted by mwsmith78 View Post
Lots of posts since my last one ... I will try to knock off all the questions.
Using 6" Mecanum wheels with tapered rollers (from AndyMark). Wheels are correctly mounted. The robot drives correctly w/o PID loop - although it does tend to have rotation error. Given that it works well before attempting closed-loop control, I believe that points to the software.
If I understand correctly about the PID post - the I & D gain values are time constants and for tuning purposes should start HIGH and work down. Meanwhile, the proportion gain should start low and work up. That may explain why we were having trouble tuning. When we inserted I and/or D values, we started very small. If we want it to function as a P-only loop, is setting I and D to zero correct?
http://www.youtube.com/watch?v=KL7iZXCRtPw
In the video above, I notice the person pushing the robot and it responds to return back to a specific pointing direction. Is this based on vision camera, gyro, wheel encoders? Thanks!
Why you WANT to use a Gyro this year JesseK Electrical 10 19-01-2010 15:49
[FTC]: Anyone know how to use the Gyro? ttldomination FIRST Tech Challenge 0 31-01-2009 21:19
Ever use a helicopter heading hold gyro before? seanwitte Electrical 7 16-01-2008 12:59
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Gyro Chip: How To Use archiver 1999 3 23-06-2002 21:57
