Re: Questions re Install etc from C++ user
Check out the FIRSTForge WPILib project that you can see here: http://firstforge.wpi.edu/sf/projects/wpilib. The Documents area has a Getting Started with Java.pdf file that describes the installation process. There is also a FAQ in the Wiki area that will probably answer most questions.
