Go to Post you know you have overdosed to first when while you are reading all of these things, you can smile and say "oh yeah, i miss doing that" and then, you start to tear up and scream "I MISS FIRST!!!" - amanda547 [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 10-01-2011, 15:01
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Minibot climb rate
We have not received our FTC parts yet, obviously because the orders went in today . I have a couple quick questions and then a result of quick calculations based on assumptions.
What are the weights of the following items?:
NXT controller, Tetrix motor, 12v battery pack, HiTechnic motor controller.
I did some very ballpark calculations based on ideal situations. If we can build a robot weighing less than 5 Lbs, it should be able to climb the pole in less than 7 seconds.
Does that sound right?
Unread 10-01-2011, 15:05
Brandon Holley's Avatar
Re: Minibot climb rate
What are you basing your calculations on? Overall output of the motors (ie: power)?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-01-2011, 15:10
billbo911's Avatar
-Brando
Yep! I chose to run the calculations close the motor's max efficiency. I also chose to use the largest wheel I could find that appeared to be legal.
Unread 10-01-2011, 15:27
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
This calculation is actually very easy using the work-energy thorem.
Power = Work / Time
Work = weight * height
Therefore:
Time = (weight * height) / Power
Example:
Motor power: 8.43 W (Tetrix motor)
Efficiency: 0.85
Weight: 5 lb * 4.4545 N/lb = 22.27 N
Height to climb: 2.1 m
assume gearing for peak power.
then:
Time = (22.27 N * 2.1 m) / (8.43 W * 0.85)
Time = 6.53 sec
This is the FASTEST time. If you make the wheel big enough that the torque on the motor causes the motor to move away from the peak power point, the minibot will climb SLOWER, not faster. In other words, bigger wheels aren't always better.
Unread 10-01-2011, 15:40
billbo911's Avatar
Power = Work / Time
Therefore:
Example:
Efficiency: 0.85
then:
Time = 6.53 sec
I looks like your numbers and mine are spot on. I took a different approach, but the result is the same within .1 seconds.
Just so others can see where I got my numbers, I ran it through the JVN Calculator.
Unread 10-01-2011, 15:48
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Seems like everyone is forgetting the possible use of surgical tubing to shoot that bot up the pole much much faster.
Also you can use 2 TETRIX motors.
-Borna Emami
Team 0x27
Unread 10-01-2011, 15:52
billbo911's Avatar
Who says we are forgetting?
Unread 10-01-2011, 15:56
That's how I would it approach it as well. 7 seconds doesn't leave much time for lining up/deployment.... *Must* *Climb* *Faster*
-Brando
Unread 10-01-2011, 16:14
billbo911's Avatar
-Brando
Again, you are spot on. With only 10 seconds to deploy the Minibot and get it to climb the pole..... Every millisecond you shave off the climb rate, the better chance you have. Deployment has to be perfect. No slippage can be tolerated in the drive. It all has to be done right if you intend to grab the 30 points!
Think about dragsters. Getting off the line is just as important as how fast you go down the track. It's all about "elapsed time".
Unread 10-01-2011, 16:30
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Yesterday we built a simple pole climber out of Vex parts with two 3-wire motors, 4 wheels, old vex microcontroller, and a battery. I'm hoping the FTC motors are more powerful (they're specs say they are) because it takes it about 10 seconds to climb 10 ft.
The minibot challenge will be more difficult than people think this year, mostly due to the timing allowed for it.
Unread 10-01-2011, 16:31
Originally Posted by Duke461 View Post
The minibot doesnt have to get there in those 10 seconds of alloted end game time. remember 469's robot last year?
<G68> Scores will be assessed when the MATCH ends and all objects in motion come to rest, or 10 seconds elapses, whichever comes first.
You might be right, but it's still a bit ambiguous. I'll refer to Gary's post
in this thread
I'm gonna need a clarification from the Q&A before I'd feel comfortable committing to getting an extra 10 seconds.
On the other hand, I want our minibot to be the first one to the top every single time, thus I'm not planning on our minibot needing an extra 10 seconds.
-Brando
Unread 10-01-2011, 16:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I think this shines the light on deployment mechanisms just as much as it shines the light on the climbing minibot. Teams won't know if they're lined up properly until the 10 second mark, which means that a missed deployment is as disasterous as a slow robot.
Good catch with the <G68> rule, though I don't think it effects who wins the race. It would simply dictate whether or not last place always got the 10 points, even after the buzzer.
GitHub
Unread 10-01-2011, 19:38
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
During brainstorming, my team used the minibots in the kickoff video as a reasonable estimate, which appeared to climb the pole in 4-5sec.
--Ryan
FRC 766, 2015-, Mentor
Unread 10-01-2011, 21:36
Jibs Jibs is offline
FRC #2506 (Saber Robotics)
Jibs is an unknown quantity at this point
So the calculation above is based off one motor?
Unread 11-01-2011, 01:28
TGA Reaper's Avatar
TGA Reaper TGA Reaper is offline
AKA: Kevin
TGA Reaper is an unknown quantity at this point
Question: What is the estimated ideal weight for the mini bot?
