Go to Post Just be nice. It works better in the long run. - Libby K [more]
  #31   Spotlight this post!
Unread 10-01-2011, 15:52
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Addressing the scoring pegs
Originally Posted by SteveGPage View Post
Blue light on, feed blue square tube
Red light on, feed red triangle tube
No lights on, feed white circle tube (I figured this would be better than having both lights on, in case one light was obstructed and the feeder fed the wrong tube.)
"Blue light on, but obstructed" appears the same as "no light on" to the FEEDER; you'll still get a wrong tube from time to time.
(since 2004)
  #32   Spotlight this post!
Unread 10-01-2011, 15:58
SteveGPage's Avatar
SteveGPage SteveGPage is online now
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
I know, I thought of that, too. I figured we could say to the feeder -
"If you don't see a light, take a second look from a different angle, if you can, and see if there is an obstruction first."
If they just saw a blue light, and the red was obstructed, I was concerned they wouldn't think twice about that and wouldn't take a second look.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
  #33   Spotlight this post!
Unread 10-01-2011, 16:05
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The feeders will have to see any signals while robot approaches in the lane. At the window is too late as time will be lost trying to find the right/desired tube. Ideal situation is tube is projected from slot before robot gets there to take it. A good analyst will be able to have color for next time and the robot with this time grabs and leaves. Oh, and for both feeder sides.
then there's the matter of we ran out of that color, boss! what now? How does feeder feedback missing info? to whom? Standing order for absence or sequence? This feeder guy better not be what is called in the popular parlance a "bottom feeder!"
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #34   Spotlight this post!
Unread 10-01-2011, 16:10
SteveGPage's Avatar
AKA: Steve
Originally Posted by Tetraman View Post
Cut out large shapes out of paper (around 10 inches), and glue them to cardboard/foam core/matte board. Cut out the shapes and attach a wrist band to the back of the board. Analysts can wear the shapes along their arm when not in use. When it's time to contact the Feeder, the Analyst takes off and holds up the right shape for the Feeder to see.
Making sure that the Feeder sees what shape is needed before the robot comes to pick it up will be key.
That's a good idea, especially for any teams that don't have some kind of on-board light indicator. I would think it would be preferable of the signal came on the robot, from the team driver, just so the Analyst doesn't have to look down, select the shape, then wave it until the Human player saw it - but that's not to say it couldn't be done that way. I think it would be good to have those shapes available for those other teams.
  #35   Spotlight this post!
Unread 11-01-2011, 00:29
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
That's an interesting point, and a scenario that I'm sure may come up from time-to-time.
The feeder could possibly raise an arm or two arms, while giving the 'bot whatever color(s) they have left, just to indicate that they acknowledge the request, but had no tubes of the appropriate color left.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #36   Spotlight this post!
Unread 11-01-2011, 00:51
FRC #2170
The analyst from our team will be carrying a clipboard with marker on a lanyard. S/he will cross out each of the nine shapes on each side of the field as they are passed or thrown out. that is, keep an inventory of which tubes are available. I'm hoping this will keep our alliance partners from random failures to get the "right" tube.
  #37   Spotlight this post!
Unread 11-01-2011, 01:03
synth3tk's Avatar
AKA: David Thomas
That should fall in line with the rule that goes along the lines of allowing you to bring a clipboard or other (non-powered) strategy device. I've only skimmed the rulebook once, but I'll have to go open it up to find this one.
EDIT: Here we go.
<T26> Devices used solely for the purpose of planning or tracking strategy of game play are allowed inside the ALLIANCE STATION, if they meet ALL of the following conditions:
- Do not connect or attach to the OPERATOR CONSOLE
- Do not connect or attach to the FIELD or ARENA
- Do not connect or attach to another ALLIANCE member
- Do not communicate with anything or anyone outside of the ARENA.
- Do no include any form of enabled wireless electronic communication (e.g. radios, walkie-talkies, cell phones, Bluetooth communications, WiFi, etc.)
- Do not in any way affect the outcome of a MATCH, other than by allowing TEAM members to plan or track strategy for the purposes of communication of that strategy to other ALLIANCE members.
  #38   Spotlight this post!
Unread 17-01-2011, 21:18
woogit's Avatar
woogit woogit is offline
1778 ALUMNI 4434 ALUMNI
AKA: Emilie Woog
no team (Chill Out)
woogit is an unknown quantity at this point
Agreed. We are planning on putting lights on the robot to indicate which one we want.
Have you found that lights are legal? Both my team and a sister team are thinking that using lights would be illegal as per R02 C and R15. We have started thinking about using something like a rotating card that had the three colors and only displayed one at a time, so that we wouldn't interfere with light sensors.
"We have a marketable hooker."
Dean's List Finalist 2010
  #39   Spotlight this post!
Unread 17-01-2011, 22:53
SteveGPage's Avatar
AKA: Steve
I would think the only thing we would have to worry about, would be <R02> C, and we would have to make sure the lights don't, in any way, mimic the vision targets. <R15> doesn't apply, since it wouldn't be a "non-functional" decoration. It would certainly have a designed function. I guess we should ask the GDC about R02, though.
Thanks!
