Go to Post You can learn just as much from building a small robot as you can from a large bot because all of the key concepts are the same. - Greg Needel [more]
  #46   Spotlight this post!
Unread 10-01-2011, 12:18
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: <R11> Dimension wrong?
We hosted a 23 team FLL tournament this weekend (it was the only date we could get a venue) and everyone (and more importantly I) was pretty beat by Saturday evening. (I was setting up the kick-off course on Saturday morning early so I was gone pretty much from 6:30 to 7:30.) So we gave the kids time off until our meeting this evening. Now I have to wonder tonight whether we should really have two design tracks, one for the 60" and one for the 213.4 cm dimensions?
The design implications are pretty significant depending on which rule is correct. If it is 60", I think it makes mecanum and swerve drive much more likely, because there will not be a lot of room to use reach to get tubes onto racks. If it is 213.4 cm then more designs are possible.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
  #47   Spotlight this post!
Unread 10-01-2011, 12:24
Chris is me's Avatar
AKA: Pinecone
Originally Posted by GaryVoshol View Post
Unlike previous years' cylinder rules, the BUMPERS are excluded from the measurement this year - thank goodness if the measurement is really 60 inches. See <R11-B>.
Because the front bumper is in the way of your mechanism, it effectively counts (while the back bumper does not)
  #48   Spotlight this post!
Unread 10-01-2011, 13:06
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
My point was that having the bumpers on the front side means the manipulator has to accomodate that as well - it most likely means a longer arm to get to the ground.
In 2007 - the last tube game, the bumper requirements were different.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
  #49   Spotlight this post!
Unread 10-01-2011, 13:09
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
These limitations also affect your thinking about how big the drive base should be. If you go for a smaller base, you'll get more room to extend your manipulator. No wonder they say the minibot cannot go after the game pieces. Mini, mini, Mini, go fetch!
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #50   Spotlight this post!
Unread 10-01-2011, 13:47
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Minibot deployment mechanisms could be built to help get a little more room out of this restriction because the minibot itself (The portion that detaches from the hostbot) is not considered in volume limitations.
From <R11>
For the purposes of determining compliance with the weight and volume limitations, the items listed below are NOT considered part of the ROBOT and are NOT included in the weight and volume assessment:
A. the 12V battery and its associated half of the Anderson cable quick connect/disconnect pair (including no more than 12” of cable per leg, the associated cable lugs, connecting bolts, and insulating electrical tape),
B. BUMPER assemblies (including BUMPER covers, if appropriate) that are in compliance with Rules <R07> and <R08>,
C. the OPERATOR CONSOLE, and
D. the MINIBOT.
So if we were to only touch the minibot from the back you could extend it past the 60" mark(or whatever the dimension truly is).
  #51   Spotlight this post!
Unread 10-01-2011, 13:51
GaryVoshol's Avatar
Cogito ergo arbitro
By my reading, the MINIBOT is not even included in the STARTING CONFIGURATION. Wow.
(since 2004)
  #52   Spotlight this post!
Unread 10-01-2011, 13:54
AKA: Pinecone
Cool, all my team has to do is Velcro a minibot to a swing-out PVC stick. A drawer-like design reaches less far because of the circle.
  #53   Spotlight this post!
Unread 10-01-2011, 14:03
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
I definitely agree with your point. No cutouts in the bumpers definitely hurts compared to the 07 bots. The bumper zone this year does begin at 1" though, so theres some consolation.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #54   Spotlight this post!
Unread 10-01-2011, 15:50
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Well I hope that the official answer comes quick.
Hard to come up with potential designs at this point, but my guess is that they will stick with the 60" rule.
  #55   Spotlight this post!
Unread 10-01-2011, 16:48
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
-Brando
Could you tell me the rule which specifies the bumper zone this year? I haven't been able to find this dimension in "The Robot Rev -" or "The Game Rev -" Thanks
  #56   Spotlight this post!
Unread 10-01-2011, 17:04
Mc,
The dimension is in the definitions for Bumper Zone. I have asked to include it in the bumper rules in the future.
  #57   Spotlight this post!
Unread 10-01-2011, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
Um, thanks to all for showing me that square robots don't (easily) fit into round holes. While this doesn't prevent an arm, it certainly adds to the challenge of using one.
Deploying minibots won't be as much of an issue: If I have an 8" square minibot, I have about 3" between the edge of the minibot and the pole (assuming minibot is centered on the 1.75" pole). 18+3=21, I only need 15-3=12. Maybe a 24" stroke pneumatic piston to whack the minibot onto the pole....
Inspection: I propose that we supply 60" I.D. right cylinders of infinite height to each venue for inspection. OK, even 30 feet tall would be impressive...
  #58   Spotlight this post!
Unread 10-01-2011, 22:42
robodude03's Avatar
robodude03 robodude03 is offline
AKA: Rene Haro
FRC #1538 (The Holy Cows)
Team Role: Tactician
robodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond repute
Absolutely agree, this is causing our team to branch into 2 separate design pathways waiting to hear an update from FIRST. I do hope that they stick with the metric rule for this :/
Team 1538 - The Holy Cows
2015 Championships - Quality Award sponsored by Motorola
2014 Championships - Media and Technology Innovation Award
2013 Championships - Chairmain's Award Winner and Newton Finalists w/ 217 & 1986
2013 to Present - 1538 Mentor (Digital Media/Strategy)
2004 to 2012 - 399 Mentor/Coach
2000 to 2004 - 399 Driver
  #59   Spotlight this post!
Unread 10-01-2011, 22:49
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The rule gives you two possible diameters that your robot must stay within, 60" or 213.4 cm. I know which one we're using.
Seriously, I have a strong hunch the correction will turn out to be 84". Looking at the table, it is easy to imagine how the 60" could have been a typo, mixed up with the 60" in the starting height box. How likely is it that you would accidentally pull the number 213.4 out of the air as a typo?
  #60   Spotlight this post!
Unread 10-01-2011, 23:06
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by jspatz1 View Post
THow likely is it that you would accidentally pull the number 213.4 out of the air as a typo?
It's not that I'm worried about. It's the cylinder starting at 84" and the GDC revising it to 60" to give us all headaches then leaving the conversion that worries me.
