Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
  #31   Spotlight this post!
Unread 10-01-2011, 17:55
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Mini-bot Ideas
When I saw the little guy on the game animation, I instiantly figured we could use Hexbug parts. I was thinking of how cool it would to have a modified Ant Hexbug race up the tower.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #32   Spotlight this post!
Unread 10-01-2011, 18:01
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: Mini-bot Ideas
I personally think as of now with the current rules, launching a minibot up the tower, while it starts at the base is legal. I do not think firing the minibot across the field is however as I look at the definition of deployment and safety. Also to whoever said the tennis ball idea I'm 99% sure that wasn't in the list of parts for the minibot.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #33   Spotlight this post!
Unread 10-01-2011, 18:19
AndrewMcRadical's Avatar
AndrewMcRadical AndrewMcRadical is offline
FRC 888 - FTC 3113
AKA: Pontius
FRC #0888 (Robotiators)
AndrewMcRadical can only hope to improve
Re: Mini-bot Ideas
parts list
  #34   Spotlight this post!
Unread 11-01-2011, 19:16
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Re: Mini-bot Ideas
just keep in mind everyone... It's not going to take very much force at all to trigger the thing at the top so all the minibot has to do is reach the top before another does... Given that the bot has only 10 seconds to reach the top, at that velocity it will most definitely trigger.
RHS Senior 2011
  #35   Spotlight this post!
Unread 12-01-2011, 13:55
Dragon Princess's Avatar
Dragon Princess Dragon Princess is offline
AKA: Katheryne
FRC #3722 (Green wave)
Dragon Princess has a spectacular aura aboutDragon Princess has a spectacular aura about
Re: Mini-bot Ideas
<G19> was reinstated that a host bat can't launch the mini bot up the pole, or contribute to the vertical movement, and energy for vertical deployment cannot be stored in the minibot before deployment.
It also states that the minibot has to be deployed on a tower or else a penalty of the highest race score is implied.
I think that now throwing the minibot from the hostbot should be out of the design, it seems as if they want us to build the minibot like a FTC team would.
<R92> A. has TETRIX components that are not in violation of any other rules.
From the Dragons to the Green Wave! Make a Splash!
  #36   Spotlight this post!
Unread 12-01-2011, 15:28
lil'est lavery's Avatar
lil'est lavery lil'est lavery is offline
AKA: Megan Lavery
FRC #0116 (Epsilon Delta)
lil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant future
Re: Mini-bot Ideas
Thank you,
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). Violation: The TOWER on which the MINIBOT is DEPLOYED is disabled. If the MINIBOT is DEPLOYED on something other than a TOWER, then the ALLIANCE’S TOWER upon which the highest RACE SCORE was earned will be discounted.
<G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel).
Who Team 116?
  #37   Spotlight this post!
Unread 12-01-2011, 21:58
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Mini-bot Ideas
Now that we've received some design changing news, does anybody have non-stored-energy-that-contributes-to-the-vertical-movement-of-the-robot ideas?
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
  #38   Spotlight this post!
Unread 12-01-2011, 22:21
pfreivald's Avatar
AKA: Patrick Freivald
Re: Mini-bot Ideas
I don't know that there would be anything more efficient than wheels, to be honest. (Given the design restraints.)
I don't mind the FTC thing... I just wish that we had to use the battery/no-stored-energy restriction and **weren't allowed** to use wheels...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #39   Spotlight this post!
Unread 12-01-2011, 22:33
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Mini-bot Ideas
One of my friends mentioned corkscrews. I dont know how it would work, but it would be interesting.
  #40   Spotlight this post!
Unread 12-01-2011, 22:34
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Re: Mini-bot Ideas
Originally Posted by Hawiian Cadder View Post
i think the plan with my team is to use the main robot to "Launch" the minibot, rather than have it move under its own power. it should work alright. i also think that our mini-bot wont have any electrics, entirely potential energy driven.
I'm sure that the robot has to move under its own power after the first 18 inches of the pole. (also sure you can't use springs)/.
  #41   Spotlight this post!
Unread 12-01-2011, 22:39
wilsehn wilsehn is offline
FRC #2996
wilsehn is an unknown quantity at this point
Re: Mini-bot Ideas
didn't read everyones but the robot has to be self driven-that means no springs or rocket boosters the general sensus seems to be that putting the robot on the pole is quicker than having it drive off the 'hostbot' so likewise it would be good for teams to have a deployment system that does not require the mini to drive.
  #42   Spotlight this post!
Unread 13-01-2011, 19:17
FatBabyJezus's Avatar
FatBabyJezus FatBabyJezus is offline
IczyG
FRC #2204
Team Role: Webmaster
FatBabyJezus is on a distinguished road
Re: Mini-bot Ideas
Hmm. How about utilizing magnets, like a maglev train?
Use the magnets to attach to the steel pipe, then flip a switch and propel it to the top?
Would it work?
I love the world.
Go humans.
  #43   Spotlight this post!
Unread 13-01-2011, 19:56
SAMBURGER's Avatar
SAMBURGER SAMBURGER is offline
AKA: Sam Johanson
FRC #2557 (SOTA Bots)
SAMBURGER is an unknown quantity at this point
Re: Mini-bot Ideas
Team Update #1 clarifies <G19> to make spring-launching a MINIBOT illegal. The HOSTBOT can't give any upward motion to the MINIBOT. The MINIBOT must climb using only a motor powered by its battery, with no other stored energy permitted.
Team 2557, SotaBots, destroyer of worlds.
  #44   Spotlight this post!
Unread 14-01-2011, 08:54
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Re: Mini-bot Ideas
That's not word for word. It just has to be electrical energy then converted to mechanical energy.
This might sound like a dumb question, but is an electromagnetic still considered an acceptable mini-bot part (AA. magnets)?
  #45   Spotlight this post!
Unread 14-01-2011, 09:40
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Mini-bot Ideas
