Go to Post There is a really bad trap most people fall into, when presented with data they tend to trust it. This is dangerous. - Andrew Schreiber [more]
Unread 10-01-2011, 20:10
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
New Classmate Software for Veteran Team
We recently purchased a new netbook to replace our classmate that was stolen We heard that veteran teams with new DS would need something equivalent to the rookie USB drive. Where do we need to go in order to get the necessary software to get our new netbook up and running?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 10-01-2011, 20:17
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: New Classmate Software for Veteran Team
I think Kate Pilotte (the KOP coordinator) said something during kickoff about needing to call FIRST for help with getting an appropriate image if you had something other than the 2010 or 2011 Classmates.
Unread 10-01-2011, 23:15
I find it hard to believe that FIRST would produce a restoration key with custom drivers for every single team who bought a custom laptop. Kate did say to let them know if you got a 2011 key and had a 2010 laptop or vice-versa, but I suspect only the two existing keys are available.
Assuming that 1671 did not get the new classmate, and rather bought a random netbook, you'll need to install the software manually. Install the LabVIEW update, then the Utilities update, then the driver station update as detailed on the driver station update page. http://joule.ni.com/nidu/cds/view/p/id/2263/lang/en If you plan to do development on the netbook also, install the appropriate programming software from the DVD in the KOP prior to the updates.
Unread 11-01-2011, 19:28
vhcook's Avatar
Reader of Things
AKA: Victoria
I can't imagine it being anything but an administrative nightmare, but I found Kate's video and at 0:46 she did indeed ask teams with exotic driver stations to email FIRST for help.
Unread 11-01-2011, 22:11
Andrew Nabors
AKA: Andrew Nabors
Thank You Everyone! We emailed frcteam@usfirst.org yesterday but haven't heard anything yet. I did not know of the frcparts@usfirst.org email address.
Unread 11-01-2011, 23:41
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
What's the model of the classmate did you get? My team also got another classmate but It was a different model than the 2010 model. I used the vet image and it worked but I was missing some drivers that I obtained on the classmate website. Other than that It worked fine.
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Unread 12-01-2011, 00:22
Andrew Nabors
AKA: Andrew Nabors
At first we weren't sure why we needed to contact FIRST for new netbooks for veteran teams then learned it was mainly just for the drivers. We actually didn't get a classmate, we purchased another netbook locally so we could have it quickly. Now that we know the only real difference was the drivers we are going to proceed with using the veteran key to flash our netbook.
Thanks again everyone for your help.
Good Luck This Year!
Unread 12-01-2011, 01:45
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I strongly recommend against using the thumb drive that came with your kit on anything other than the classmate that it is intended for. The drivers will not match and you will just have headaches. If you already have an OS on it, then all you need is the Tools from the NI DVD and the Driver Station update installer. If you need an OS too, I recommend you get it elsewhere.
-Joe
