Go to Post As a team leader if I do not INSPIRE I have failed, and I do not like to fail. - Mike Martus [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Unread 01-10-2011, 08:25 PM
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
Re: Mechanum wheel programming in C++
my understand is that we need to specify each motor/wheel assembly , ie all four individually as each wheel is connected indepedently to a single motor.
so then do we use the above statements for each motor/wheel assembly?
thanks
have you actually written some code just to move the bot with mechanum wheels?
Unread 01-10-2011, 08:33 PM
thanks
You take the commands from the joysticks and you process them (it's called inverse kinematics) to create the 4 wheel speeds.
The drive interface could be a single 3-axis joystick, or two 2-axis joysticks, or any other input device(s).
Mecanum has three completely independent degrees of freedom:
fore/aft
strafe (right/left)
rotate (turn, yaw)
A mecanum vehicle can perform all three of these motions simultaneously.
Here's some reference C code for you:
// 3-axis joystick interface to a mecanum drive
// define your driver interface,
// in this case a 3-axis joystick:
forward = -Y;
right = X;
clockwise = Z;
// put any drivability adjustments here for forward, right, and clockwise,
// for example gain, deadband, etc:
// if rotate gain is too hot, tweak it down:
clockwise /= 2;
// add deadband so you don't get strafe when you don't want it:
if ((right>-0.1)&&(right<0.1)) right = 0;
// now apply the inverse kinematic tranformation:
front_left = forward + clockwise + right;
front_right = forward - clockwise - right;
rear_left = forward + clockwise - right;
rear_right = forward - clockwise + right;
// finally, normalize so that no wheel speed command
// exceeds magnitude of 1:
max = abs(front_left);
temp = abs(front_right);
if (temp>max) max = temp;
temp = abs(rear_left);
temp = abs(rear_right);
if (max>1)
  {front_left/=max; front_right/=max; rear_left/=max; rear_right/=max;}
// you're done. send these four wheel commands to their respective wheels
Questions? Fire away.
Unread 01-17-2011, 11:03 PM
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
fore/aft
strafe (right/left)
rotate (turn, yaw)
forward = -Y;
right = X;
clockwise = Z;
clockwise /= 2;
if (max>1)
So with that code I can just pop it into my code and it should work or will it have to be modified.?
Unread 01-18-2011, 11:12 AM
Originally Posted by tomy View Post
So with that code I can just pop it into my code and it should work ...?
That was not the intent; it is reference code. It lacks window dressing (variable declarations etc), and you need to decide whether or not you want to shape the joystick response curves (gain, deadband, etc). I recommend that you study and understand it, then tailor it for your specific application.
Unread 01-25-2014, 10:09 AM
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
What about field-centric? My team tried this out a few times but got really weird results. Would the following code snippet be correct?
[...] gyro->Reset(); float theta = gyro->GetAngle(); [...]
yVal2=(float) (yVal*Math.cos(theta) - xVal*Math.sin(theta));
xVal2=(float) (yVal*Math.sin(theta) + xVal*Math.cos(theta));
When we tried using this in our mecanum code method the robot could drive straight but would jitter and twitch if we tried to rotate it (like some robots do when their power draw exceeds the operating power of the motor controllers when your battery is low).
Unread 01-25-2014, 10:57 AM
WPILib now has mecanum code, with field-centric option. Take a look at that (use just use it as-is).
Unread 01-10-2011, 09:01 PM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
thanks
You have 4 individual motors one for each wheel but you don't have to deal with them yourself, the WPI library will take care the rest for you. So when you instantiate the RobotDrive object, you will need to initialize it with four motors in its constructor. Once you define the RobotDrive object with four motors, you can make the MecanumDrive_Polar call to drive it around. The RobotDrive object will figure out the power and direction for each wheel for you.
Either:
RobotDrive(UINT32 frontLeftMotorChannel, UINT32 rearLeftMotorChannel,
	UINT32 frontRightMotorChannel, UINT32 rearRightMotorChannel,
             float sensitivity = 0.5);
Or:
RobotDrive(SpeedController *frontLeftMotor, SpeedController *rearLeftMotor,
	SpeedController *frontRightMotor, SpeedController *rearRightMotor,
And yes, we were using Mecanum wheels last year so we did write some code for them.
