Go to Post You've got to love the great connection between FIRST teams, and their members. - zakk [more]
Unread 10-01-2011, 17:41
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Hostbot/Minibot Communication
Anyone have ideas of how to get the hostbot and minibot to communicate prior to deployment? I would need 3 states, so a limit switch won't do, two would though. I have also considered color, any other ideas?
Unread 10-01-2011, 17:50
Happy Birthday! EricH EricH is offline
Re: Hostbot/Minibot Communication
You are allowed 2 light switches.
It may also be possible to hit buttons on an NXT, but that requires some nice precise positioning.
Unread 10-01-2011, 18:07
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
I might consider putting a countdown on the nxt program. Have every autonomous program set a delay in for 2mins and 5 seconds, after that no need to worry about turning it on right before the launch
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 10-01-2011, 18:13
mwtidd's Avatar
AKA: mike
Are these light switches at the driver station? ie can they be used to control it.
i actually need to control the minibot during the match.
Unread 10-01-2011, 18:23
Bjenks548's Avatar
AKA: Brendan
Not sure what your planning on, but keep in mind G<46> MINIBOTS may only be used to climb the TOWER. Violation: Yellow card
Unread 10-01-2011, 18:37
mwtidd's Avatar
AKA: mike
Hmm, I wonder what defines using. Technically having a minibot on you as a 15lb counter weight is using it for something other than climbing.
Unread 10-01-2011, 21:13
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Well that is just Physics we are planning the same thing but I don't know how to either time it right or control it to do the climbing.
Unread 10-01-2011, 21:30
DonRotolo's Avatar
Back to humble
FRC #0832
OK, how to use it for example:
You have a battery and motor connected through a push-type switch. Your Hostbot pushes the minibot on to the pole (say, with a pneumatic piston, or maybe a big rubber band...), and the pole presses the switch.
Depending on the rules, you can either use the switch to complete the circuit to power the motor, or you can use the switch to signal the NXT brick to turn the motor on (using the motor controller that's allowed).
Hope this idea gets you started.
Unread 10-01-2011, 21:31
mwtidd's Avatar
AKA: mike
Not if you have a movable conterweight system. Then you are actively using your minibot to balance your robot. Personally I think the rule was meant to avoid minibot roaming the field during the endgame, but that's just my personal opinion.
Unread 10-01-2011, 21:51
FRC #0581
Yes it does thanks
ya you are right it is only to prevent minibots from roaming the feild
Thanks every body.
