Go to Post We discovered this problem on the ship day (sure, when else?) - Manoel [more]
Unread 10-01-2011, 20:56
jeremiahjbarnes jeremiahjbarnes is offline
FRC #2856 (Planetary Drive)
jeremiahjbarnes is an unknown quantity at this point
Defense
Hey, I am the president of our robotics team here in Lexington and was wondering how important everyone here thinks defense is going to be. It has been discussed briefly in other threads, but I thought having devoted to debate would be good. Our team is leading towards a primarily defense strategy, but there are several members who think offense is more important. I would particularly like to hear from teams who participated in rack n roll seeing as the scoring mechanisms could end up being very similar. Much thanks.
Unread 10-01-2011, 21:07
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Defense
Defense will be important, since the game requires a lot of movement on the field, but defense won't win a match - you need to score to do that.
Also, defense strategies can be somewhat ineffective due to the field layout. One robot can't prevent an opposing bot from leaving its LANE, since there are two exits separated by a pole. Pinning is ten PENALTIES (@ 3 points each), and you need to get at least 6 feet from them for at least 3 seconds for it to not be called - all to hold them for only 5 seconds. Blocking may be the only moderately effective strategy, but not if you can be pushed out of the way...
Have the team watch the Grant Imahara video off the FIRST site that talks about Team 111, and follow that design process. Decide on capabilities, rank them in order of importance, then find mechanisms and methods to implement those capabilities.
Maybe defense with a great minibot? Or just build a simple elevator bot?
Unread 10-01-2011, 21:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Defense
Don,
I'm not sure escaping from the lane will be THAT easy. The space between the tower base and the wall is something like 36" wide. A narrowbot with bumpers ends up about 34.5" wide. So you've got a slightly tight squeeze there. I think you could hinder someone fairly well by blocking off the side escape and then chasing them down the rail till they either run into your own lane or have to try to turn to escape. As long as you're fast enough to chase them, I think you could keep them corralled pretty effectively.
Unread 10-01-2011, 22:17
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Defense
The GDC seems to be really pushing away defense this year--which makes me think that it may be an extremly powerful strategy.
Our team is going for the "minibot with defender robot" strategy, and we'll have to see how it works out. Historically, winning alliances have been two offences, and a defender.
Unread 10-01-2011, 22:25
Uriah Uriah is offline
FRC #4531 (STEMpunk)
Uriah is an unknown quantity at this point
Re: Defense
Our team has been debating this alot.. i personally feel that a good defensive bot with a outstanding minibot will be better then a robot with a great arm and an ok bot. Offence has to travel the length of the field if you have to have it fed to you, or around half maybe if you are able to throw them over (and have a good human thrower) so a defensive robot would at least lengthen the time of travel, which could really hurt them... or you could puppy guard a robot and keep them in there scoring zone, this takes up space for the other teams to get in and score.
Unread 10-01-2011, 22:29
AKA: Simon Bohn
Re: Defense
Another role for a defensive robot we have been discussing is the "punter" idea, which plays the same role that a defending robot of last year played--moves the gamepieces into the required zone.
Unread 10-01-2011, 22:32
Re: Defense
we've been discussing that too, but more plowing them. we think that kicking them wouldn't move them efficiently.
Unread 10-01-2011, 22:35
AKA: Simon Bohn
Re: Defense
Remember, your only able to posses/herd ONE piece at once, so pushing more than one is considered against the rules.
Unread 10-01-2011, 22:37
Zachary Pilarsk Zachary Pilarsk is offline
FRC #1711 (Raptors)
Team Role: Electrical
Zachary Pilarsk is an unknown quantity at this point
Re: Defense
when I originally was the video I thought defense would be the best bot to build we have since changed to make an offence bot but I still think defense will make or break teams in finals by stoping the effective scorer on the other team
Unread 10-01-2011, 22:40
Re: Defense
yea i know that, which could be a problem if the field is littered with pieces. if its like last years rule with herding the balls, it had to be obvious you were purposely trying to move to balls at once.. if u accidentally run into one and back up, i dont think they will penalize you for it.
Unread 10-01-2011, 22:42
AKA: Simon Bohn
Re: Defense
Just so we dont get any misunderstandings:
<G34> ROBOTS or HOSTBOTS may only POSSESS or HERD one GAME PIECE at a time.
Violation: PENALTY
It is important to design your ROBOT so that it is impossible to inadvertently or
intentionally control more than one GAME PIECE at a time. Inadvertent contact will
be not be considered HERDING and will not be penalized.
HERDING – controlling the movement of a GAME PIECE. A GAME PIECE shall be considered
HERDED if it is in contact with the floor and, as the ROBOT moves in the direction of the GAME
PIECE, the GAME PIECE is pushed in the same direction in a controlled manner, but does not
remain in the position relative to the ROBOT if the ROBOT changes direction or orientation.
Unread 11-01-2011, 00:49
Re: Defense
Defense wins qualifying rounds, offense wins championships. --Paul Copioli, FRC 217 mentor/strategist/drive coach, in 2005.
If you can't score a single tube, then all your opponent has to do is get one tube on and they win. A good opponent could probably get 2-3. A great opponent will probably get 4-5. If you can't stop every single one of those, your alliance partners had better be able to play defense.
Conversely, if it's a massive scoring game, some well-timed defense can slow an offense enough.
However, there is one thing to consider:
It's a whole lot easier to plan for offense and convert to defense than it is to plan for defense and convert to offense. I talked to a rookie team last year. Their kicker was not working well (at all?), but they played good defense. I went over and suggested that maybe they should focus on playing D and work on the kicker as they had time. They ended up picking the next day. OK, so they were knocked out in quarters, but that's what happens when good D meets great O that can score through good D.
Unread 11-01-2011, 01:07
Chris is me's Avatar
AKA: Pinecone
Re: Defense
Nuh uh. They need a logo on the top row with an autotube, if you have a minibot.
Remember all the "defense + lifter" bots in 07? Yeah.
Unread 11-01-2011, 01:55
Re: Defense
They've got plenty of time to get that, if they got the Ubertube (no defense is allowed in automode) and managed to bust one or two through while you were playing D. Now you go to deploy a minibot, and they grab the last tube for the logo and slam it into place. Your defense just lost the match, unless you can get away from the tower before they're in the zone.
Not counting the other 4 robots on the field, of course.
IIRC, none of the robots on Einstein in 07 was a defense and lifter. Every last one of them (at least in 3/4 of the alliances--my memory is shaky on the last one) had tube placement capability and used it at least once. All of the robots I remember there were either tube/defense or a full hybrid (tube, ramp, defense). I also remember a defense/ramp being scored against autonomously by a dead-reckoning program run by a full hybrid, though not on Einstein.
Unread 11-01-2011, 11:32
Back after 4 years off
FRC #5279
Re: Defense
Defense is always important. Some regionals will have teams picked strictly for defense. You likely wont see this at Championships.
I reccomend to every team that I work with that they build a robot with a powerful but manuverable drive train (6-8 wheels) then you can always play defense if the situation warrents it. An Average or below average scorer with a great drive train is an incredibly valuable second pick or alliance partner.
The best example of building a robot to play offense that is also capable of switching to being a shut down defender is 177 over the last 4 or 5 years, it isn't a coincidence that they always seem to make it onto Einstein.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
