Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
Unread 08-01-2011, 18:53
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Windriver LAC 2011
We're trying to install the 2011 Windriver disc, and it's asking for the LAC. Our disc sleeve (which the CD had fallen out of) is clear plastic with no label or anything on it. Does anyone know where to find the LAC?
Unread 08-01-2011, 18:59
FRC #2605
Re: Windriver LAC 2011
Never mind. There was a mis-communication between the two software people.
Unread 10-01-2011, 19:51
dan_144 dan_144 is offline
FRC #2059 (The Hitchhikers)
dan_144 is an unknown quantity at this point
What was your solution? We are lacking the same code. I'll try restarting the computer, and I'll report back.
Unread 10-01-2011, 20:10
Forgive me. I read the instructions, and now it works perfectly.
For those who still don't have it working, you're supposed to select permanent activation rather than a temporary one. There's a file named FRC_2011_install.txt and you select that as the file it prompts for. It should work then.
The PDF readme has more information.
Unread 10-01-2011, 22:50
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
Also, if you are installing over an old version of WindRiver [which I initially tried, then went back and uninstalled everything in disgust] you will need to select New Activation Info [not sure of exact name] rather than Current Activation info.
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
Unread 11-01-2011, 09:29
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by dan_144 View Post
There's a file named FRC_2011_install.txt...
How does one obtain this file?
Do you have to install labview stuff to get it?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 11-01-2011, 09:37
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
It should be in the root of the WindRiver install disc.
Unread 11-01-2011, 12:30
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Haven't looked at the disc this year but for last year, you can find the file on:
<drive>:\Distributions\Wind River\FirstRobotics_2010_install.txt
So I assume you should find it at a similar location.
Unread 11-01-2011, 15:21
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Yes, that's where it is.
So convenient I didn't even think to look there.
