Go to Post This looks like a job for duct tape! - JoeXIII'007 [more]
Unread 10-01-2011, 22:52
Dr.Ward Dr.Ward is offline
FRC #2852
Dr.Ward will become famous soon enough
Pivot arm or telescoping-pivot arm?
Team 2852 DM High Voltage.. St.Catharines Ontario
We've been brainstorming for the last couple days and aside from our base which is already completed a 4 wheel plaction 4 wheel omni dropped down via pneumatic cylinder driven by a 5 CIM motor chain drive configuration with a very low COG we are leaning towards an arm of either telescoping/Pivot or simple pivot....
Dimension are 36" by 12" for the robot with bumbpers...... we figure we can safely get about 100" of reach from a 3 section pivot arm easily
We listed some pros and cons of each and we would just like some extra input.... If anyone has any of their own concepts or input it would be greatly appreciated.
Unread 10-01-2011, 23:01
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: Pivot arm or telescoping-pivot arm?
Emphasis mine. You're only allowed 4 CIMs. <R45>C.
Unread 10-01-2011, 23:03
moler moler is offline
FRC #0772
moler is an unknown quantity at this point
Hey I think you can only have 4 CIM motors this yr
Unread 10-01-2011, 23:48
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
I would say that without some other form of extension you will only be able to receive tubes from the slot, it is possible using a very well designed grasping apparatus to score on all three levels with a simple pivot. The problem only come if you happen to drop a tube... Thats my input.
I would also do some quick math to figure out if your design allows you to score on both the upper, lower, and middle parts of the rack.
Unread 10-01-2011, 23:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
One thing to consider, any arm of any sort complicates programming, the more joints there are, more stress for the programmers. Make sure your programmers are competent before designing something complex
Unread 10-01-2011, 23:55
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
only 4 cims this year bro.
Unread 10-01-2011, 23:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
While I realize it's possible to fit 100" of reach into a infinitely tall cylinder, keep in mind the maximum size requirements for during the match is a 60" cylinder.
Unread 10-01-2011, 23:58
Chris is me's Avatar
AKA: Pinecone
Please read the rules, particularly the volume constraints.
Unread 11-01-2011, 00:18
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Or 84, depending if you "do" metric or not.
Unread 11-01-2011, 00:41
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
If they aren't seasoned-enough to program something "complex", then someone best teach them, or they start doing some mad Googling.
While this is a competition, remember that learning is also important, too.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 11-01-2011, 11:57
FRC #2852
Our team is 3 years into FRC were great programmers and even better engineers.... weve taken 3rd in competition last year and now lower place than 10 in other.....
I beleive i read a revised rule about being able to sue now 5 CIM motors this year.... Other than that as to the reach doing the math you can roughly get about 100" of reach with a 3 pivot arm having it fold up and being able to jsut stay inside the 60" volume constraint...
Anyways... What are your teams thinking of doing?
P.s... KRETZ IS AN AWESOME NINJA ASSASSIN.....
Unread 11-01-2011, 12:10
AKA: Ryan
FRC #2614 (MARS)
Emphasis mine. Could you cite the rule? I would love to have an extra CIM...
Unread 11-01-2011, 12:20
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Revised Rule?!?! Update 1 isn't out yet...
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 11-01-2011, 12:36
ttldomination's Avatar
Sunny
Giving us credentials doesn't make your statements any more correct. We all have copies of the rule book.
<R45>C. one or two additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to four, and no more, 2½” CIM motors can be used on the ROBOT.
And initially, you can't be outside the 28'x38'x60'. But AFTER the match starts, your robot is bounded by a 60" diameter, infinitely projected cylinder.
- Sunny
1648: 2013-2014
5283: 2015
Unread 11-01-2011, 13:53
Sunny
Revised Rule R45 was outdated yesterday as of an update on the usfirst site.... check out the rules section... 5 CIM motors are now allowed
I copied and pasted that rule from the page on the FIRST website. I'm staring at it right now.
And FIRST generally doesn't upload new rules without putting it up in the updates section.
- Sunny
1648: 2013-2014
5283: 2015
