Go to Post Do whatever you must to survive within the rules, but please stay within the rules. - Kevin Sevcik [more]
Unread 10-01-2011, 23:11
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Clamshell Activation Code
I'm helping a relatively new team activate the Windows 7 OS on their new clamshell. Would anyone happen to know the activation code required?
Unread 10-01-2011, 23:20
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Clamshell Activation Code
If Win7 came with the laptop, the product key is usually on a sticker on the bottom of the laptop. If Win7 is installed from a retail product, you should have a product key in the retail box. If Win7 is already pre-installed on the machine, chances are you just need to connect the laptop to the Internet to activate the OS.
Unread 10-01-2011, 23:30
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
There is a .bat file available for download on the KOP page. All it contains is the following command:
start /min slmgr /rearm
Run that, restart, and try to reactivate.
Unread 11-01-2011, 09:16
Originally Posted by mikets View Post
...you just need to connect the laptop to the Internet...
That's the part which always trips us up.
I'm more than a little irritated at the growing requirement for a live internet connection in order to be an FRC team. We don't have a usable one at our shop. I did manage to get a temporary link working yesterday, with an annoying firewall keeping us from downloading everything we would have liked to, but it was enough to let Windows 7 on the 2010 Classmate decide it was genuine. We'll have similar issues if we want to install WindRiver.
Unread 11-01-2011, 12:42
mikets's Avatar
Software Engineer
That's one of our issues too. I am interested in knowing what other teams use for Internet connectivity for checking updates, search for datasheets etc. We usually need Internet connectivity in two places: our school for which although the school district has Internet connectivity, students are not allowed to access it. At the Joint Practice Field that several schools in our region built in some sort of warehouse where there is no Internet. In the past, if we are luck, some mentors may have a 3G/4G link on their phone that we may be able to tap into. We also consider a temporary subscription to 3G/4G/WiMax type of connectivity. But we are not able to find a service provider that will not charge you an arm and a leg for it. They usually involve activation fee, a 1 or 2 year contract etc. We just need it for the season (about 3 months). What is the most cost effective way to get mobile Internet?
Unread 11-01-2011, 13:22
mikets's Avatar
Software Engineer
Sorry, I should not change the subject on this thread. I have re-posted my question on a new thread.
http://chiefdelphi.com/forums/showth...888#post996888
Unread 11-01-2011, 23:45
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
All right, here's the thing... I followed the instructions word for word from this PDF: http://usfirst.org/uploadedFiles/Rob...tion_Rev_A.pdf
The documentation doesn't say anything further about activating after running the Classmate_Update.bat file. I've run the Classmate_Update.bat, I've seen the successful message, and I've restarted. Unfortunately, I still cannot activate. It gives me error code 0x8007232B, and I have 3 days left.
I found a solution, but it requires a Windows Product Key...
I also noticed that AVG was NOT installed as the documentation says it was.
Perhaps there were two different versions of the 2011 software released?
I'm actively searching for solutions, but if anyone else has encountered this problem and found a working solution, could you be as kind as to help a fellow team out?
Also, for what it's worth, I performed the fix to get back our 5GB of data on the image, and it worked. I'm also waiting on the antivirus (Avast) to install and then I'll update the Classmate software from the link provided in the documentation above.
Thanks!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 11-01-2011, 23:59
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
I too was frustrated by this, it kept saying that the key was not valid or something like that, so I ended up using a 7Pro key that I already owned
Unread 12-01-2011, 00:36
RyanN's Avatar
RyanN
I have a key from MSDNAA, but I'd rather not use that...
As an update... well I'm all up to date as far as the required updates go. I'm currently updating Windows, so I'll give it another go after it's up to date.
Now I'm curious... are there veteran teams that have been able to update and activate successfully? I'm finding quite a few on the FIRST Forum having the same issue.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 12-01-2011, 01:22
[raises hand] Yes, there's one right here.
Unread 12-01-2011, 08:26
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
We were able to successfully update and activate our classmate by following the How to Set Up Your 2011 Driver Station guide on the new kit of parts website.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 12-01-2011, 09:34
RyanN's Avatar
RyanN
Hmm... I don't know what it is. All I know is that I'm getting a "DNS name does not exist" error. You can see the update batch file on the desktop. I get the conformation that it was successful. I read up on this quite a bit last night and it appears there is nothing I can do.
I did find a KMS file in the user folder. Does anyone else see this file, and if so, is the address the same?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 12-01-2011, 09:52
Boiler Up
AKA: John Downey
That is the error we were getting until we ran Classmate_Update.bat as mentioned in the "Windows 7 Activation" section of How to Set Up Your 2011 Driver Station.
John Downey
Unread 12-01-2011, 10:03
RyanN's Avatar
RyanN
Yep... as you can see, that's the file sitting on the desktop. I've run it a few times and it says that it's successful and to restart. I restart, and it still fails activation.
Also, another curious thought... was AVG installed when you updated the classmate image? I find it weird that such a discrepancy would exist in the documentation still.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 12-01-2011, 10:19
Your Classmate is connected to the Internet, right?
