Go to Post In theory, there is no difference between theory and practice. In practice, however... - Alan Anderson [more]
Unread 09-01-2011, 19:02
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Laptops: Will You Guys Use Them On The Robot?
If you are trying to create a robot that works well, and that is all you're trying to do, offboard image processing (offboard the crio) is un-needed for most tasks.
Vision processing works phenominally well with high contrast differences, or with self-lit objects. Thus the white on black rings last year, the 2007 lights etc. The pink over green of lunacy were problematic much of the time due to lighting. The colors of the tubes and changing shape depending on viewing angle even more so.
I love the idea of a robot that utilizes high amounts of vision process to automate tasks. However, I believe you will struggle to consistently track game peices, etc over the varying lighting levels seen on FIRST fields.
Last year you could adjust the robot to see the targets from close to 30 feet away at a framerate more than high enough to aim and shoot balls. You only need ONE FRAME to calculate your angle and distance to target, then use the gyro to turn and fire the ball. Your target wasn't moving.
That is much removed from Lunacy where you needed at least several images and a timestamp to calculate the relative motion of the trailer to your robot and calculate some rather simple leading-angles and distances.
Likewise, this year, the rack is not moving. You need only 1 image to calculate your position and distance and get the angles you need to drive. The crio is more than powerful enough to do that.
Unread 10-01-2011, 01:46
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Here's an idea ...
Kinect?
Unread 10-01-2011, 01:57
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Originally Posted by drakesword View Post
Here's an idea ...
Kinect?
already been discussed... uses lasers => illegal
Unread 10-01-2011, 14:02
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
I would really only want to put a desktop onto it, but even then the benefits are far outweighed by the inconvenience. Firstly, you would need a powerful battery to power a desktop. Laptops are too integrated to mess with and take apart AND put onto a robot.
I like the CRIO. It's a nice system, as buggy as our old one may be.
Unread 10-01-2011, 23:21
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
You just need to convert the DC to AC; the 12v DC would convert to 110v AC.
Oh it seems like we are not doing autonomous this year. It seems that we lack the funds. It is the first time we would go to 2 regionals for the first time this year and we already invested too much money for that. There will be less money for the actual robot this year. Lets just hope my idea gets implemented, I do not like conformity.
Unread 11-01-2011, 03:17
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
It seems like it would be much more reasonable to not go to AC at all. You just need a DC-DC ATX power supply. There are plenty here. We did this on our robot last year. It was harder last year, though since we had to swap out cooling fans for kit-of-parts fans and had to run with no CMOS backup battery.
-Joe
Unread 11-01-2011, 09:34
I don't understand. Autonomous mode is just a matter of programming. You spend time on it, not money, and everyone has the same amount of time.
Unread 11-01-2011, 09:38
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by Alan Anderson View Post
Autonomous mode is just a matter of programming. You spend time on it, not money...
Well, if you're convinced you can't do autonomous unless you bolt a desktop computer to your robot, then you might think otherwise.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
