Go to Post It's not GP, its not un-GP, its just a strategy. - AndyB [more]
Unread 10-01-2011, 22:10
AlexBond AlexBond is offline
FRC #2361
AlexBond is an unknown quantity at this point
Articulated arm vs Forklift style arm
I was wondering if anyone had any experience with forklift style mechanisms in FRC bots. I would be interested in hearing the pros and cons of such a system when compered to a twin joint articulated arm.
Unread 10-01-2011, 22:16
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Articulated arm vs Forklift style arm
Here are some of the pros and cons we've come up with while narrowing down are choices of a manipulator mechanism.
Forklift Pros:
-We have experience with it
-Simple to do
-Doesn't require a lot of machining
Forklift Cons:
-Not very robust (in our experience)
-Requires upkeep during competition
-Can't change orientation of object (in itself, requires more mechanism to do so)
Articulated Arm Pros:
-Can manipulate object in a variety of fasions
Articulated Arm Cons:
-Power Consumption
-Weight
-Complex
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 10-01-2011, 22:17
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
I would suggest looking here: http://thebluealliance.net/ for the 2007 matches. I think doing your research by watching the matches will give you the best idea of what to do. Remember, just because a complicated-looking device works very well from the past, it is no guarantee of what your team can produce. Stay within your capabilities and get the 'bot done early, so you can practice with it!
Good luck!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 10-01-2011, 22:23
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
The biggest con with an arm this year is the 60' rule!
Unread 10-01-2011, 22:27
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
772 has ahad great advantigase with a fork lift and was one of my first ideas when i first saw the game this year ... here is some pictures of the fork lift from 2008 overdrive.
http://photos.sabrerobotics.com/disp...album=45&pos=0
It was extremely strong and could even pic up it elf by doing chin ups on the bar. but was heavy having hains linked from top to bottom a few times.
Unread 10-01-2011, 22:29
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
dont you meen 60in. not 60 feet please get your units right
Unread 10-01-2011, 22:53
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Make sure you analyze the degrees of freedom of the gripper/forklift/articulated arm manipulator. What degrees do you NEED to perform the task? What degrees will HELP perform the task? What degrees will be EASILY CONTROLLED? What degrees will be EASILY PROGRAMMED (remember repeatability is very important)? What can be EASILY CREATED & TESTED with your team's resources? Turn around time is very important to give the programmers time to work out kinks with autonomous and for the drivers to get some practice in. From there you can decide which rotational and/or which translational degree(s) of freedom will best allow your robot/team to complete the task.
Good luck, I hope this helps!
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 11-01-2011, 01:02
AKA: Bryant
I Mis-shifted lol
Unread 11-01-2011, 01:11
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I would say a con for the articulated arm is the complexity of the programming compared to the fork lift. Its only a bit trigonometry, but its not awfully complicated. To make it great is really hard
Unread 11-01-2011, 01:45
Chris is me's Avatar
AKA: Pinecone
An arm can't possibly be harder than a fully autonomous robot...
Unread 11-01-2011, 01:56
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I said COMPARED. anyways I was gonna do a very simple mechanism, like the platforms that are like a giant car jack. IDK what they are called, but they are powered with pneumatic actuators. I thought that since they extend to a known distance, I can easily have 2 levels of height. First for the 2nd level and Second for the top. Yea apparently I can not do full automation this year due to the lack of fund... We used it for the 2nd regional, I thought my mentor said we are only doing 1 and that we had enough funds for all the sensors and stuff, apparently not.
I mean great as in: http://www.youtube.com/watch?v=vu6APoC0IOA or http://www.youtube.com/watch?v=5cORKyFr_7E
Unread 11-01-2011, 03:05
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Elevator is the way to go!
Go REX!!!
Unread 11-01-2011, 09:04
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
Better yet, use metric units, 213.4 cm. http://www.chiefdelphi.com/forums/sh...ad.php?t=88589
(since 2004)
Unread 11-01-2011, 09:08
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
good info were between these ideas to
Unread 11-01-2011, 09:38
davidcone315 davidcone315 is offline
FRC #3154 (Robo-Razziatore)
Team Role: Student
davidcone315 will become famous soon enough
My team is considering using a vacuum to pick up the tubes instead of an arm, does anybody think that is a bad idea?
