Go to Post All the same lessons that can be learned or taught with custom drive trains can also be learned or taught with custom manipulators and scoring mechanisms, and the latter is far more likely to set your team apart in the competition. - Jared Russell [more]
Unread 11-01-2011, 00:38
voteforandy1 voteforandy1 is offline
FRC #3131
voteforandy1 is an unknown quantity at this point
Exclamation Robot Cameras
What Cameras are compatible with the C-RIO and Drivers Station? I know that the AXIS camera works, but which models? And are there any other brands or products that will work? Please answer soon. Thanks!
Unread 11-01-2011, 00:42
Re: Robot Cameras
The brands that have been tested are the Axis 206 and the Axis M1011.
If you are willing to do the work to get a good electrical connection and modify WPILib, you can get other IP cameras that return JPG or MJPG or BMP formats to work. Be sure to look at camera latency, as many IP cameras are more SW based and tend to lag the real world by are far greater amount.
Greg McKaskle
Unread 11-01-2011, 00:45
FRC #3131
Re: Robot Cameras
Which of the two you mentioned is best? Specifically, which has the least lag time?
Unread 11-01-2011, 00:52
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Robot Cameras
I believe they have similar performace, but the 206 is out of production.
The M1011 is easy to find, either thorugh Andymark or other online retailers.
Eric Haskins KC9JVH
Unread 11-01-2011, 01:02
Rileyx2 Rileyx2 is offline
FRC #3131 (Gladstone Robotics)
Rileyx2 is an unknown quantity at this point
Question Re: Robot Cameras
How hard is it to edit/modify WPILib, and is that something that would take 20 minutes or a few days of work?
Unread 11-01-2011, 02:26
Re: Robot Cameras
That would depend on how many mistakes you make.
I'd recommend using WireShark or a similar tool to log communication with the camera from a vendor utility. Combined with documentation from the vendor, you should be able to reverse engineer it in hours to a day or so.
Greg McKaskle
Unread 11-01-2011, 02:37
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Robot Cameras
I suggest only make child classes that inherit the stuff you need. That is why polymorphism and inheritances exist. The camera library is essentially just a wrapper for the National Instrument's library. You can't modify much with the camera, its all NI's proprietary library.
Unread 11-01-2011, 02:41
Re: Robot Cameras
The vision processing or image analysis tools are built from the NI Image Analysis tools.
Getting images from the camera is straight up TCP calls to the camera's HTTP server.
Greg McKaskle
Unread 11-01-2011, 10:44
Re: Robot Cameras
Thanks for the info and the fast replies!
