Go to Post drill holes, that should fix it - E. The Kidd [more]
Unread 11-01-2011, 05:49
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
bumpers for interior perimeter
we were planning to have a cut out in the front of our frame to allow for our grasping mechanism ot be dropped to the ground. Will we need bumpers inside the cutout? now i dont thinks we do but i just want to make sure
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 11-01-2011, 06:32
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: bumpers for interior perimeter
As stated in <R07> you will need bumpers to cover the entire bumper perimeter. Please look at how bumper perimeter is defined in section 1.6.
BUMPER PERIMETER – the polygon defined by the outer-most set of exterior vertices of the BUMPERS when they are attached to the HOSTBOT. (To identify the BUMPER PERIMETER, wrap a string around the BUMPERS at the level of the BUMPER ZONE - the string describes the polygon.)
This being said, you can have a cut out if you would like, but the bumpers will still be in the way.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 11-01-2011, 08:14
GaryVoshol's Avatar
Cogito ergo arbitro
No, you will not need BUMPERS inside the cutout. But you will need a BUMPER spanning the cutout, and the cutout cannot be more than 8 inches wide. See <R07> A and K, including Figure 4-3.
(since 2004)
Unread 11-01-2011, 08:41
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
"and the cutout cannot be more than 8 inches wide. See <R07> A and K, including Figure 4-3."
I believe that your interpretation is incorrect. <R07> and the corresponding pictures is describing the backing needed for the bumpers.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 11-01-2011, 08:57
GaryVoshol's Avatar
Cogito ergo arbitro
Can you explain how I misinterpreted this?
Originally Posted by <R07-K>
The BUMPER backing must be supported by the structure/frame of the ROBOT (i.e. the gap between the backing material and the frame must not be greater than 1/4” and no section of BUMPER greater than 8” may be unsupported).
(since 2004)
Unread 11-01-2011, 10:21
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
Here are the sound bites you should be thinking about that pertain to the discussion.
If implemented as intended, a ROBOT that is pushed against a vertical wall in any STARTING CONFIGURATION will always have the BUMPER be the first thing to contact the wall
BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). As part of the 100% coverage, BUMPERS must protect all exterior corners of the FRAME PERIMETER. For adequate protection,
BUMPERS segments must have a minimum length of six inches
BUMPER – an assembly designed to attach to the exterior of the HOSTBOT and constructed as specified in Section 3.4.2, Bumper Rules.
Unread 11-01-2011, 12:46
Gary, Figure 4-3 clearly shows that a gap of 1/4" or less can go longer than 8" long, and a gap of less than 8" can go deeper than 1/4". Two separate parts are marked OK that are either longer than 8" or deeper than 1/4".
So either the rule is not written clearly or the pictures are wrong. Assuming the Figure 4-3 is right, the rule should really read something like, "Any gap that is deeper than 1/4" && wider than 8" will be considered unsupported." If the figure is wrong, all three marked areas are illegal.
Unread 11-01-2011, 12:53
GaryVoshol's Avatar
Cogito ergo arbitro
The cutout as described by the OP is an unsupported section of the BUMPER. Thus it is limited to 8".
I can see the disconnect between the written rule and the picture, and why my post might be misunderstood. I believe the GDC considers a bumper with 1/4" or less gap to be a supported bumper, not unsupported.
(since 2004)
Unread 11-01-2011, 12:55
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
So if i have a gap in between my drivetrain side plates that is about 4.75 inches across and 4 inches deep but still have an entire front bumper that goes all the way across, that is legal?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 11-01-2011, 12:57
GaryVoshol's Avatar
Cogito ergo arbitro
According to figure 4-3, Yes. According to the text, ???
(since 2004)
Unread 11-01-2011, 12:58
Yep, unsupported needs to be that short--and spanned by bumpers is going to make life very interesting for those that were around in 2007.
dodar, the answer would be Yes, legal, assuming I'm reading the rule correctly. It's less than 8" across, even though it's more than 1/4" deep.
Unread 11-01-2011, 12:59
AKA: carroll
so lets say i have a gap that is less than 8 inches long but more than 1/4 inch deep. there will be bumpers on each side of the cutout but i cannot put bumpers in front of the cutout beucase that is where the grasping mechanism must go to fit inside the dimensions of the starting robot is this illegal or not?
Unread 11-01-2011, 13:02
Your frame perimeter is not 100% protected. Therefore, you are in violation of <R07-A> and will not be allowed to compete until there is 100% protection of the frame perimeter.
Unread 11-01-2011, 13:12
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
I guess we'll just have to agree to disagree until Q&A starts up and answers this question. I believe that they can have the cut out. An open space would not make contact with a vertical wall LOL
I'd have to go back to the archives but I do not see the rule being much different than 2 years ago when when cut outs were permitted.
I believe that a few teams that plan on using forklift type mechanisms are planning on having a cutout so they can pick up parts from the floor. Only a guess.
Unread 11-01-2011, 13:18
GaryVoshol's Avatar
Cogito ergo arbitro
The rules changed significantly.
Originally Posted by 2008 Rule <R08>
STANDARD BUMPERS must protect a minimum of 2/3 of the perimeter of the ROBOT within the BUMPER ZONE.
See the difference?
(since 2004)
