Go to Post Haters gonna hate; kill 'em with kindness. - Taylor [more]
Unread 11-01-2011, 00:49
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Feeder Bot
I got my first opportunity to mess around with the logo tubes this evening and I noticed that they are very heavy duty and it is possible to throw them pretty far( I was able to get about 30 to 40 feet). The circular one flies the best but the other ones go almost as far. this got me thinking that it would be possible to make a robot that sat in front of one of the player stations and got fed logo tubes. It would then throw them across the field to its alliance partners saving them long trips across the field. Has anyone else considered doing something like this? Has anyone done anything like this before?
Unread 11-01-2011, 00:55
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
Re: Feeder Bot
our team has decided to go against throwing pieces onto the field at anytime based on the fact the piece becomes available to the opposing teams when put past the lane.
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
Unread 11-01-2011, 01:01
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Feeder Bot
Very interesting idea. Would make for a very unique and sought after robot, so long as the robot is able to get those tubes to fly far enough to your side of the field with 100% success. Maybe it wouldn't sit there, it might drive out to the edge of the blue feeder zone and shoot them off there...or it just hands pieces to allied robots.
If I had an entire robotics team for myself, I'd actually do that.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 11-01-2011, 01:03
Chris is me's Avatar
AKA: Pinecone
Re: Feeder Bot
We tried throwing tubes and couldn't get them to track very straight.
r2davis2's Avatar
r2davis2 r2davis2 is offline
no team (Purdue FIRST Program)
r2davis2 is an unknown quantity at this point
Re: Feeder Bot
This idea has definitely come up in 294's discussions, the fear however is that you really need to get the full distance of the field to avoid your opponents stealing the tubes you've thrown, it will also be very hard to actually build this successfully. But the biggest issue we came up with is that unless you are able to launch at-least 3/4ths of the field you can probably count on a few human players being able to match your distance.
That being said, I do really like this idea from the stand point of a well-built alliance, and would definitely prototype it a little to make sure it is reasonably feasible.
294 - Beach Cities Robotics(2009-2011)
- 2010 World Champions(thanks 67 and 177)
LA regional 2012 Field Reset
Boilermaker Regional 2013 Referee
Unread 11-01-2011, 01:16
FRC #2635
Re: Feeder Bot
In my opinion a well designed mechanism to throw the intertubes should outperform a human arm, the main thing that I am also worried about is the intertubes curving a lot and going out of the field, although you could probably minimize this as much as possible through trial and error with the throwing machanism.
Unread 11-01-2011, 01:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Feeder Bot
Apparently throwing of any sort is out of the question for our team... They want full control of the tubes at all times.
Unread 11-01-2011, 02:59
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Feeder Bot
Don't aim too high, you might hang a tube on the opponent's tower and ruin their chances of getting a minibot up.
Go REX!!!
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Re: Feeder Bot
Darn, and here we thought we had a truly original idea. Anyways, we're strongly considering it, though overcoming the tendency of the tubes to not go straight is of course an issue.
Human players can and probably will do it at some point, but I think a bot could do it better if only because they're far more likely to actually reach the safe zone. The only problem is if it gets there and bounces out...
Unread 11-01-2011, 08:27
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Feeder Bot
I recall this problem from 2007. There weren't too many rings that scored directly on the rack. Whether thrown frisbee style or vertically "rolling" in the air, they usually swerved.
It would only seem to be compounded when throwing the triangle and square.
(since 2004)
Unread 11-01-2011, 08:52
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Feeder Bot
Keep in mind that the tubes would pretty much have to be launched with some sort of spin about the vertical axis to have a controllable flight. The arc that is created could be repeatable in a mechanical launching device. If done well, this idea certainly has potential, but keep in mind it would require at least one of your alliance partners to be able to floor-load the game pieces (or catch them in midair).
Hi!
Unread 11-01-2011, 09:37
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Feeder Bot
The team realizes they will be in a variety of alliances with other teams, don't they? The longer the time before an actual event that the team comes to grip with the A-factor, the better their strategy will be. Just ask the team how they will convince an alliance team who thinks throwing will be OK.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 11-01-2011, 10:10
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
Re: Feeder Bot
I would think it's not an issue of getting them to go where you want it, but about getting the most tubes over to your side of the field as fast as possible.
Say you were able to only catapult the Circle tubes. Well, just catapult a Circle and then grab yourself a triangle or square with an arm. Score with the arm and if everyone was too busy to take care of the circle, which I think will occur more often then not, score the circle. You'd get points and Logos much faster that way. Sure you'd need to pick up from the floor, but even if you had your human player throw them, you'd have to pick them up from the floor on your opponent's side anyway.
Unread 11-01-2011, 10:24
Techokami's Avatar
Techokami Techokami is offline
FRC #2122 (Team Tators)
Techokami is an unknown quantity at this point
Re: Feeder Bot
We do plan on throwing them in, as it would be faster than inserting them through the slot, however it's hard to get good accuracy or distance with the square and triangle.
Unread 11-01-2011, 10:50
mahumnut's Avatar
mahumnut mahumnut is offline
FRC #1418 (Vae Victus)
mahumnut is an unknown quantity at this point
Re: Feeder Bot
1418 discussed this as well, we tried throwing the pieces around and the only way we could get them to go anywhere with any sort of distance or accuracy was with a bunch of spin. Designing a mechanism to impart enough spin and launch it across the field length would be REALLY tough. We decided against it.
The other problem is you have to drive all the way across the field from the starting position to get to the loading lane. Because you can't cross the middle line in autonomous, you would have to wait for teleop to start. After a few games, I'm assuming other teams would be able to catch on and block you from ever getting into position. You would also have to avoid hitting the towers which are in the way.
Even if you were to build a robot that could launch the pieces, I still don't think it would be a game breaking strategy such as Las Guerrillas last year.
