Go to Post Before you fix something, it's worthwhile to make a concerted effort to figure out why it failed. - Ether [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 09-01-2011, 23:25
zachmartin1806's Avatar
zachmartin1806 zachmartin1806 is offline
FRC #1806 (S.W.A.T. Robotics)
zachmartin1806 has a spectacular aura aboutzachmartin1806 has a spectacular aura aboutzachmartin1806 has a spectacular aura about
Re: Max Score Speculation
Originally Posted by ahollenbach View Post
(Although I suppose a technical error *could* occur with the minibot race, but it's doubtful.)
<G67> The RACE SCORE is assigned to each ALLIANCE based on the place of finish in the MINBOT RACE (ties each receive the points for that place)
Unread 09-01-2011, 23:33
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
if every field element performs optimally, then there will be no ties. I assume we're assuming since no tubes will break, the sensors will do their jobs, and everything else goes smoothly?
Though to be absolutely technical, yes, you could potentially get 168.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 09-01-2011, 23:36
Does anything ever go smoothly at a regional? haha
Unread 11-01-2011, 09:55
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I'm speculating that Murphy will rule at least one match, resulting in a four-way tie for first. 30 points each for the climbs that reach the top but not timed.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 11-01-2011, 10:04
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
I highly doubt there will be a tie. Too many variables to ensure that your two mini-bots will hit at the very exact same time. That is, unless if a bot was able to hit the top .1 second slower then first also is given first, then it might be different.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 11-01-2011, 10:19
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Let's say, just for fun, that your alliance has 3 ubertubes on the top row of one station, covered by a circle and square in their respective spots. There's 12 seconds left in the match. Do you place the triangle or deploy the minibot (your robot design and placement on the field don't allow for both to occur in this timeframe)?
Hi!
Unread 11-01-2011, 10:22
ATannahill ATannahill is offline
AKA: Alex Tannahill
*Speculation*
If you place the triangle you get
a. 6 points for the traingle over an uber tube
b. 18 points as double because of the logo
If you go for the minibot you will get 30, 20, 15 or 10.
At first glance, the only way the minibot wins out is if you get the 30.
But look again, if you go for the minibot you will take 10 possible points away from the other alliance.
I would go for the minibot.
- Arizona North
Unread 11-01-2011, 10:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Beginning of the regional, I would go for the minibot if you believe you have a chance at 1st or 2nd place in the race. It allows your drivers to get used to placing it under pressure, shows off your capabilities and is a small gamble.
After each team has played 2 or 3 matches this answer should come from scouting data. You should have at least some idea how your minibot stacks up against your opponents and that will dictate which choice to make.
Unread 11-01-2011, 10:40
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
I'd want to know how good each team's mini-bot is.
If our alliance couldn't pull off first or second, I'm going tube. If I felt we could at least grab 2nd and 3rd, I'm going Minibot.
If it's a qualifying match, Mini-bot regardless. No reason not to show off that you have a mini-bot that can keep up with the others. However if the mini-bot is terrible and will get 4th or not even finish, might want to go for the tube.
Unread 11-01-2011, 10:43
pschre's Avatar
pschre pschre is offline
Teacher Coach
AKA: James Schreiner
FRC #0806 (Brooklyn Blacksmiths)
pschre will become famous soon enoughpschre will become famous soon enough
Send a message via AIM to pschre
Scouting mini-bots will have an added twist, to say the least, because teams are allowed (and enticed by Coopertition Points) to lend out their minibots. If teams succeed in establishing some universality for minibot deployment, as other CD threads are calling for, then you may not know which minibots you're facing, regardless of which team's hostbot you're facing, until you're practically on queue for your match.
"In this life we cannot do great things. We can only do small things with great love." -- Mother Teresa
"You give yourself to us, O Lord, then selfless let us be, to serve each other in Your name, in truth and charity." -- Robert E. Kreutz, You Satisfy the Hungry Heart
"You have the right to work, but for the work's sake only. You have no rights to the fruits of work. Desire for the fruits of work must never be your motive in working. Never give way to laziness, either...Work done with anxiety about results is far inferior to work done without such anxiety, in the calm of self-surrender...They who work selfishly for results are miserable." -- from the Bhagavad Gita, quoted in Educating Esmé
