Go to Post your time is better spent in the stands, watching what the robots actually do, as opposed to listening to the builders talk about what they're [I]supposed[/I] to do. - sanddrag [more]
Unread 11-01-2011, 11:42
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
Mecanum Newbie
Questions:
1. Is it easier to create a mecanum shaft or chain driven system?
2. Would shaft driven system with the CIMple boxes be any good?
3. How would I mount the mecanum wheels onto the shaft of a cimple box?
Unread 11-01-2011, 11:52
jeremiahjbarnes jeremiahjbarnes is offline
FRC #2856 (Planetary Drive)
jeremiahjbarnes is an unknown quantity at this point
Re: Mecanum Newbie
Are you talking about all mecanums or mecanums in front/back and rubbers on the others?
Unread 11-01-2011, 11:54
pfreivald's Avatar
AKA: Patrick Freivald
Re: Mecanum Newbie
Our robot last year was a chain-driven mecanum system, so I'm not sure what you're asking...
In terms of robustness, I would always advocate chain over direct-drive. Axles are easier to replace than gear boxes!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 11-01-2011, 11:56
Labview Maniac
AKA: Cody Ripley
Re: Mecanum Newbie
Does the KOP come with the needed spacers/ parts to run a chain driven system? Could I do this with 4 CIMple boxes?
Unread 11-01-2011, 12:01
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: Mecanum Newbie
I believe you're thinking of omnis, not mecanums.
To answer your questions:
1. There was a thread on this a while back, I'll edit this post with a link once I dig it up.
http://www.chiefdelphi.com/forums/sh...+dr ive+chain
2. We used direct-driven mecanums last year with no problems. YMMV.
3. Put a spacer on the shaft. Put a key into the keyway on the shaft. Slide mecanum(with hub) onto shaft. Insert a bolt with washers into the threaded hole on the end of the shaft to secure(I believe it's threaded for a 1/4"-20 bolt, but I could be wrong.)
Unread 11-01-2011, 12:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Mecanum Newbie
The corollary being that axles are much harder to break than chains. West Coast drivetrains are pretty successful as long as you protect the shaft and wheel from direct impacts with other robots. So if you can get a gear ratio you like for direct drive, I'd honestly go with that so you don't have to worry about chains.
Unread 11-01-2011, 12:18
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Mecanum Newbie
3. (information taken from the AndyMark.com site)
"Drive with Axle and Hub
If you wish to drive this wheel with an Axle and Hub, you can pick your hub by fitting any of the AndyMark hubs (except the Small DD Globe Hub) to this wheel. Hubs are NOT included in the price of the wheel. If this is your choice, then no bearing is needed. To install a hub onto a 6" Mecanum Wheel, use Hardware Kit 8."
Hi!
Unread 11-01-2011, 13:22
bakejame's Avatar
bakejame bakejame is offline
FRC #2993
bakejame has a spectacular aura aboutbakejame has a spectacular aura aboutbakejame has a spectacular aura about
Re: Mecanum Newbie
I too have a question about of Mechanum wheels. What is the best gear ratio (GR) to use to prevent your motor controllers from getting too hot? The CIMple Box has a GR of only ~4.8:1. Last year we used the tough box and chains and had a GR of ~13:1. At that GR we had absolutely no problems, but we really think that speed is going to be more important than it was last year. However, we still want the maneuverability of the Mechanums. Any suggestions on a safe GR that will be considerably faster than what we had last year?
Unread 11-01-2011, 14:15
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: Mecanum Newbie
We are thinking about doing a mecanum drive this year as well, and we have no experience with them in the past. I would say to use the standard toughbox that you guys were using, and see how the speed of your robot looks when built. If you would like even more speed AndyMark has several gearing options for the toughbox that would be just a simple gear change (but you need to design your bot to have easy access to the transmissions).
Hope this helps.
Good enough is the enemy of anything great!
team 1671
Unread 11-01-2011, 14:29
pfreivald's Avatar
Re: Mecanum Newbie
Well, that's the advantage of chain -- it's a relatively simple operation to change gear ratios by using different sprockets, and sprockets are reasonably cheap and easy to get.
Team 1551
I write books, too!
Unread 11-01-2011, 15:23
bakejame's Avatar
FRC #2993
Re: Mecanum Newbie
I understand that point. The question I have is what kind of GR we can get away with without burning up our Jaguars? We will definitely use chains and sprockets if we can't get the proper GR we need. We just are not sure how to figure out what the GR needed is to be safe and still fast. By the way, we have 8" Mechanums.
Unread 11-01-2011, 15:43
jethrow jethrow is offline
FRC #2594 (naskcorions)
jethrow is on a distinguished road
Re: Mecanum Newbie
if you can contact 2594 i bet we can find out together we are going to try the same thing.
Unread 11-01-2011, 16:48
doteyes9 doteyes9 is offline
FRC #3229 (Hawktimus Prime)
doteyes9 is an unknown quantity at this point
Send a message via AIM to doteyes9
Re: Mecanum Newbie
My team as well wants to implement Mecanum drive this year. I am a complete newb when it comes to programming it... Could anyone provide any insight to it at all? A labview vi with an example would be the holy grail for me right now. We were thinking of making it similar to this drive system: http://www.team1540.org/mecanum
Unread 11-01-2011, 21:33
bakejame's Avatar
FRC #2993
Re: Mecanum Newbie
I can't find your website to share contact info through. Contact me through our website: www.intechmegabots.org
Unread 12-01-2011, 19:32
Labview Maniac
AKA: Cody Ripley
Re: Mecanum Newbie
So would I be able to use CIMple boxes for a good mecanum direct drive? Or would toughboxes be overall better?
