Go to Post It's just another design constraint that needs to be dealt with. - Dave Scheck [more]
Unread 11-01-2011, 12:18
1631JD 1631JD is offline
Psychotron
AKA: Jordan
FRC #1631 (Rockin' Robots)
Team Role: Tactician
1631JD is an unknown quantity at this point
Re: More than one minibot on robot
Originally Posted by davidthefat
Even if you can have 2 bots, why waste the space and weight?
Well we are already going to build at least two minibots for the coopertition points, and if it provides beneficial to have two then why not do it?
Originally Posted by EricH
Why not put the arm on the turret? Now you can grab tubes off whatever side of the robot is handiest, and launch the minibot on whatever side is handiest--and the minibot may act as a partial counterweight to the arm if you do it right.
Full rotational capabilities are tougher--run your wires/tubing up the middle with room to twist a bit, and I think you could do it without a problem. Running up/around the side will give you headaches.
Thanks. We'll see if it will work, though the only problem could be accidental damage to the arm. That is the risk though in competitions like this so I guess its no big deal.
