Go to Post You enjoy your pepperoni pizza, I'll enjoy my cheese and peppers, and we can both agree that people that like pineapple on their pizza, while strange... are completely entitled to their opinions. - Andrew Schreiber [more]
Unread 11-01-2011, 13:18
Re: bumpers for interior perimeter
Sunshine, it's not illegal because there's a cutout. It's illegal because a short distance of frame perimeter (which, I remind you, is independent of cutouts) has no bumpers on it, and the rule says
BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT).
(emphasis mine)
If it were something like 1/4", you might have a case, as normal bumper joints are nearly that big. But to be big enough to let an arm out, it's almost got to be several inches. Try being the LRI who lets it through because it's protected despite the gap, only to have every other team at the event complain that that team just got a competitive advantage!
Cutouts were permitted a couple years ago because there was not a 100% protection requirement. IIRC, it was something like 75-80%. Starting last year, it went to 100%.
Unread 11-01-2011, 13:19
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
last year lots of teams had openings in their bumpers to allow for a kicker mechanism, pusher, etc while the cutout will be differnet the idea that the inside of the cutout would not be the first thing to touch a vertical wall in a collision it wouldnt need bumpers if you have anything that would help me make sure i am correct in this idea i would appreciate it
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 11-01-2011, 13:22
GaryVoshol's Avatar
Cogito ergo arbitro
Nobody in Michigan did, at least not among the 80% or more of teams that I saw. BUMPER coverage was required to be 100% last year too. The difference was that the BUMPER ZONE was higher last year, allowing the balls to go below the BUMPERS.
The issue is not the flat-wall test; the issue is the 100% BUMPER coverage requirement from <R07-A>.
(since 2004)
Unread 11-01-2011, 13:23
Last year, the bumpers were higher. There wasn't a single team to my knowledge that had a gap there intentionally (100% coverage again).
The frame perimeter is defined as
The visual is to wrap a piece of string around the robot. They should have used a rubber band (and I told them so during the offseason). That string will show you the bumper perimeter. You need bumpers on 100% of that string. No bumpers over the cutout, no 100% coverage, fix it before you can play.
Unread 11-01-2011, 13:33
SteveGPage's Avatar
SteveGPage SteveGPage is online now
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Just last night I commented to another mentor - "You know, I haven't seen the rash of bumper questions, like in previous years. Maybe they are starting to get it!"
Maybe they just haven't done their chasis designs, yet!
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 15-01-2011, 09:50
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
For our robot this year we wanted to have an inner angle so that when we go to deploy the minibot we could hit it with the inner angle and always be straight on to the pole is this allowed?
According to the rules "BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). As part of the 100% coverage, BUMPERS must protect all exterior corners of the FRAME PERIMETER. For adequate protection, a full segment of BUMPER must be placed on each side of the corner"
but it also says "The
BUMPER location and design have been specified so that ROBOTS will make
BUMPER-to-BUMPER contact during most collisions. If implemented as intended, a ROBOT that is pushed against a vertical wall in any STARTING CONFIGURATION
will always have the BUMPER be the first thing to contact the wall."
so reading these over we should be able to do this but we wanted to be sure before we just started cutting and welding
Unread 15-01-2011, 09:54
GaryVoshol's Avatar
Cogito ergo arbitro
Interior angles and concave sections are not allowed in the FRAME PERIMETER - see that definition.
BUMPERS may span short segments that do not have a physical frame member along the FRAME PERIMETER - see <R07-K>.
(since 2004)
