Go to Post It definitely looked like a penalty, but in FRC if it looks like a penalty and smells like a penalty, well, unfortunately it might not be. - Basel A [more]
Unread 11-01-2011, 12:47
OldBug OldBug is offline
FRC #3167
OldBug is an unknown quantity at this point
Problem Creating Netbeans Projects
Hello,
We're trying java for the first time this year, and I'm running into some problems.
I installed the 5 FRC plugins as described in the Getting Started with Java Guide (added path to the Plugins->Settings tab), and I see the FRC button on my toolbar, which supposedly indicates a proper installation. When I create a new project, I see FRC Java as a category, and I can select SimpleRobotTemplateProject, go to the next screen where I name the project and main class, etc.
But after I click "Finish," nothing happens. No errors, nothing is added to the project listing, nothing.
The folders and files are created, so I tried opening the project, but when I select the project folder (which has a regular folder icon, instead of the gear-in-a-box icon), it says <unrecognized project; missing plug-in?> in the Project name field.
Some Googling revealed this recent post, which seems similar, yet different from what I'm experiencing:
http://forums.usfirst.org/showthread.php?t=16021
All project and samples in the FRC category have this same result.
Am I missing something?
I'm using a fresh install of Netbeans 6.9.1.
Thanks!
-Kerry
Unread 11-01-2011, 13:37
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Problem Creating Netbeans Projects
That is a new one to me.
What OS are you running on?
What version of the plugins got installed?
Thanks,
- Derek
Unread 11-01-2011, 14:09
FRC #3167
I'm on Windows XP x64.
The plug-in version is 2011.3 for all 5 plugins.
Thanks,
Kerry
Unread 12-01-2011, 10:21
FRC #3167
I tried on some other OSs and had no problems, so I uninstalled NetBeans and the JDK, then re-installed everything. It solved the problem, but I'm still not sure what caused the problem in the first place.
Maybe another clue: I now seem to have a project type called "Maven" which was not in the list previously.
Anyway - it works.
Thanks for the help,
Kerry
