Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 27-08-2009, 16:12
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
pic: Team 1716 T-shirt Launcher
Unread 27-08-2009, 16:14
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
Re: pic: Team 1716 T-shirt Launcher
hey, nice work. is your tilt for the barrel only a single acting solenoid? and what brand valve are you using for it (SMC, FESTO)? just might have some helpful advice about pneumatics for you...
Unread 27-08-2009, 17:43
McGurky's Avatar
Geek
AKA: Kyle McGurk
It is a double smc solenoid. Thanks for the compliments!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 27-08-2009, 21:36
FRC #1236
if you can get ahold of two FESTO single-acting solenoids, i can give you a schematic on how to make the barrel adjust to different positions. did you think of using a Rain Bird (or something like that) electric sprinkler valve with a transformer? (i can tell you how to build it [safely]) they do work on 120 PSI that's what i'm using and it never leaks or anything. if you have any questions, just ask and i will most likely be able to help.
Unread 28-08-2009, 08:38
McGurky's Avatar
Geek
AKA: Kyle McGurk
we looked into a sprinkler valve, but decided that it wouldn't be safe to have it holding back all of the pressure. Maybe I am wrong but we just went the safe route!
we will for sure try out that festo valve today!! thanks for the heads up!!
Unread 28-08-2009, 10:52
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
I've been wanting to do one of these forever!
For valves, I would look at 1726's valve setup at http://www.chiefdelphi.com/media/photos/29086 and http://www.chiefdelphi.com/media/photos/29085
How far does it shoot with that galvanized pipe (?) resevior?
Go REX!!!
Unread 28-08-2009, 12:16
McGurky's Avatar
Geek
AKA: Kyle McGurk
we have been charging it to about 100-115 psi, and with 2 compressors it takes about 15-20 seconds to fill. The t-shirt will go about 100-120 feet at the lower position. But when the barrel is raised, the T-shirt will go about 60-80 feet, but super high in the air, I have a ton of video that we shot yesterday, I just need time to edit it, and will post it up on youtube. Overall, It shoots awesome and at the distance we are shooting and where we will be at our school football games, the t-shirt will go right over the stands... So as far a s distance, it is all we will really need!!
Again, There are more pictures posted on that facebook link that I posted in the original post!
Unread 28-08-2009, 13:43
Chris is me's Avatar
AKA: Pinecone
Now the real challenge is to write a program that will let you target a t-shirt a specific distance away from the robot
Nice 'bot. Hope to catch a T-shirt out of it someday.
Unread 28-08-2009, 20:55
McGurky's Avatar
Geek
AKA: Kyle McGurk
We are thinking about mounting another compressor but we manages to misplace the rubber standoffs to mount them. Is there anywhere they are available online? I couldn't seem to find them on the where to get more list.
Thanks,
McGurky
Unread 29-08-2009, 16:46
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Our 2009 Lunacy robot is ready to go as a t-shirt launcher with no modifications. Just need to bundle the shirts to fit in the catapult.
http://www.chiefdelphi.com/forums/at...9&d=1239427199
Shoots about 35 ft., good enough for basketball games.
If you are having trouble with air flow capacity through your valve, try parelleling 2 or 3 valves together, so they share a source, and merge their output together. We actually did this on this robot to get the cylinder speed we needed.
Unread 29-08-2009, 19:09
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Thanks,
McGurky
They are #8-32 rubber shock mounts/vibration dampers; Vex Robotics sells identical ones (P/N LINK-RUBBER-832-4PK) on this page.
SDP/SI also sells #8-32 rubber shock mounts, and McMaster has a variety of them on page 1362.
Art Dutra IV
世上无难事,只怕有心人.
Unread 29-08-2009, 19:28
McGurky's Avatar
Geek
AKA: Kyle McGurk
Awesome! thanks, I was looking for a technical name for them, but couldn't find one!!
Thanks again!!!
-McGurky
Unread 11-01-2011, 15:08
atarie101 atarie101 is offline
None #2011
atarie101 is an unknown quantity at this point
How much did this whole project cost?
pic: T-Shirt Launcher, still needs a chasis reversed_rocker Extra Discussion 54 16-11-2010 12:15
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
pic: Team 56 Trackball Launcher Test jfischer Extra Discussion 12 10-02-2008 11:54
pic: Team 1501's launcher Wayne Doenges Extra Discussion 2 21-01-2006 18:52
pic: Team 57 T-Shirt Teaser CD47-Bot Extra Discussion 7 16-02-2004 11:46
