Go to Post It makes me wish I would have paid attention in my physics class... - jwallace15 [more]
Unread 11-01-2011, 06:00
xideromri xideromri is offline
FRC #2230
xideromri is an unknown quantity at this point
Minibot questions
Can you or can you not have springs which are loaded during any part of the match?
If I can recall the manual says something about loaded springs but can you load them during the match?
Thank you,
Team #2230
Unread 11-01-2011, 06:13
Anika N. Anika N. is offline
FRC #3132 (Thunder Down Under)
Team Role: Electrical
Anika N. is an unknown quantity at this point
Re: Minibot questions
Thank you,
Team #2230
If the loaded springs are meant to be on the minibot, then no. It is not allowed. However, you are allowed loaded springs on your hostbot.
Unread 11-01-2011, 06:18
FRC #2230
can i start the match with a loaded spring? or i need to load it during the match?
Unread 11-01-2011, 07:01
u13mbenshoshan's Avatar
u13mbenshoshan u13mbenshoshan is offline
FRC #2230
u13mbenshoshan will become famous soon enough
can somebody answer his question?
this is an issue
Unread 11-01-2011, 07:05
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
From what I can tell the rules do not specifically state that you cannot have a pre-loaded spring. But they do have a warning in there that the discretion will be up to the judge. So my guess is that a large load probably cause some problems but a very small load will not.
Unread 11-01-2011, 07:16
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
IN ANY CASE - ANY ANSWER YOU GET HERE IS NOT OFFICIAL!
ONLY ANSWERS FROM THE OFFICIAL Q&A FORUM SHOULD BE CONSIDERED.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-01-2011, 08:00
GaryVoshol's Avatar
Cogito ergo arbitro
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R34> for specifications and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
[bluebox]Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe.[/bluebox]
Notice the first line, FRC ROBOTS. Per the definitions, ROBOT = HOSTBOT + MINIBOT. So stored energy is allowed in a MINIBOT as well as the HOSTBOT. You just have to store the energy in an allowable material on the MINIBOT.
(since 2004)
Unread 11-01-2011, 13:12
FRC #2230
That is very foggy it could mean just about anything, and a teams worst nightmare is to have a part or robot removed from the robot the hour before the competition.
Soooooo...
Does anyone have a quote from the manual its self allowing or rejecting the idea
We have a very close to impossible assignment. We need to build a robot in an almost impossible time frame, we need to build it with an almost impossibly strict budget, and we need to work with the minimal tools.
And yet every year we are reexcited for the challenge that will change us all.
-Matthew Team #2230
Unread 11-01-2011, 13:15
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
well if you were planning on using the spring to launch the minibot i wouldnt try that. That would be considered a safety hazard and is also not following the definition of deploying the minibot. using a spring to push somehting on the hostbot to push the minibot might be allowed but considering the amount of questions about this i think FIRST will be adressing this question in one of their updates.
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 11-01-2011, 13:20
FRC #2230
Thank you but again untill an update comes out does anyone have a quote???
BTW: when is the next update coming out???
-Matthew Team #2230
Unread 11-01-2011, 13:32
GaryVoshol's Avatar
Cogito ergo arbitro
From the Administration section of the manual (you know, the parts without the password that you had a week or so before Kickoff to study):
Originally Posted by 2.6.1
Team Updates – will be posted at: http://www.usfirst.org/roboticsprogr...nt.aspx?id=450
FIRST® 2011 FIRST Robotics Competition Manual - Section 2 - Communication Page 4 of 6
After the Kickoff FIRST will start posting Team Updates on line, Tuesdays by 5:00 PM and Fridays by 5:00 PM. Team Updates provide rules updates, important information about parts and administrative reminders/deadlines. Please note:
 Unexpected circumstances may, on occasion, delay this publication;
 Additional updates may be released, if necessary; and
 Occasionally, FIRST will publish revisions to manual sections.
(since 2004)
Unread 11-01-2011, 13:37
Please, read <R01-D>. Springs would be a robot part.
You should also note that (at least in the past) it's been allowed to have pneumatic power ready to fire while the robot is being hauled onto the field. And who ever charged a battery while on the field?
In other words, as long as it's an allowed material (found in 4.3.7--<R02> tells you what you can't use), and it's safe (the blue box), knock yourself out.
Unread 11-01-2011, 14:58
royal robotics's Avatar
royal robotics royal robotics is offline
FRC #3359
royal robotics can only hope to improve
how high does the robot have to go up the pole? and how high are the pegs?
Unread 11-01-2011, 15:09
Where's the "beating head against wall" smilie when you need it?
Read Section 2.2.5 and look at the field drawings, or search this site for the 47 combined questions on those topics. Most of them have answers--the same answers. (Search is in the orange bar at the top of the page.)
Unread 11-01-2011, 15:33
FRC #3359
section 2.2.5 of what? what manual are you talking about?
