Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 10-01-2011, 19:56
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Height of PVC pole in team version of tower
I can't seem to find the length of the pvc pole in the team version of the tower for the minibot. Does anyone know it?
Unread 10-01-2011, 20:24
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Height of PVC pole in team version of tower
I think you're suppose to not make it out of PVC,the real piece is 1 1/2" EMT (conduit) that you should be able to find at Home Depot or Lowes. It's 120" for reference.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 10-01-2011, 20:30
AKA: Brandon Liatys
In the version for teams to build in the shop, low cost, its listed as just "Pole" so I took a guess that it was PVC as almost everything else was. Thanks!
Unread 10-01-2011, 20:37
KevinGoneNuts's Avatar
KevinGoneNuts KevinGoneNuts is offline
AKA: Kevin
FRC #0675 (Tech High Robotics)
KevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud of
well it would just be best for the minibot if it was the same material as what it would be in the actual competition fields. the differences in friction could be an important factor.
Unread 10-01-2011, 21:31
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
As well as the differences in friction, the minibots are, as I found more or less implied, supposed to use magnets to stay attached to the pole. Unless you have some super pvc, I don't think the same electromagnetic field applies.
Academic Student (Forever)
Unread 10-01-2011, 21:46
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Brandon,
The team version of the tower uses the same material as the normal competition tower. Item #3 on drawing TE-11008 references a drawing from the competition game element drawing GE-11061.
The tower pole is a 10 foot 1-1/2" Steel EMT (aka electrical conduit). There are different types of steel conduit. Make sure you get "EMT."
Unread 11-01-2011, 09:35
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by CalTran View Post
... the minibots are, as I found more or less implied, supposed to use magnets to stay attached to the pole...
That's one option that was given, not a mandate by any means.
(since 2004)
Unread 11-01-2011, 09:37
Brandon Holley's Avatar
Originally Posted by D.Allred View Post
Brandon,
This information is correct. The EMT conduit can be found at almost every Home Depot, Lowe's, or other various hardware stores.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 11-01-2011, 11:16
team1512's Avatar
team1512 team1512 is offline
FRC #1512
team1512 is an unknown quantity at this point
diameter of pole in team version of tower
I am reading in several posts about a 1.5 od inch emt pole. It seems the drawings are calling for a 1.75 inch od. can anyone clarify. thanks.
Unread 11-01-2011, 12:00
Re: diameter of pole in team version of tower
You are looking for a 1.5" EMT pipe. The 1.5" is a pipe size that adheres to a set of regulations, but doesn't necessarily adhere to familiar fractional sizes.
Get 1.5" EMT pipe.
-Brando
Unread 11-01-2011, 13:54
D.Allred's Avatar
1 1/2" EMT has an outside diameter of about 1 3/4". Here's a link to an EMT sizing table.
http://www.republic-conduit.com/defa...%20Conduit.pdf
Unread 11-01-2011, 13:57
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Get 1.5" EMT pipe.
-Brando
To confirm if I was to measure a 1.5" EMT pipe, the O.D. would be 1.75"? (or roughly 1.75")
Unread 11-01-2011, 15:16
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Perhaps the updates will clarify the outside diameter.
A 1.5" EMT pole has a 1.9" OD.
As noted earlier in this post, there are references to something different. I would get clarification just to make sure.
Unread 11-01-2011, 15:18
You are correct.
See this website: http://www.home4c.com/conduit.htm
Scroll to the bottom to view EMT sizes.
-Brando
Unread 11-01-2011, 15:54
D.Allred's Avatar
Glenn,
You have the wrong conduit. You have "rigid" conduit, not EMT. 1 1/2" rigid conduit has a thicker wall with an OD of 1.9".
