Go to Post but then again, isn't FIRST a sport? I mean come on now, our championship is nothing less than the super bowl. :) - Arefin Bari [more]
Unread 11-01-2011, 05:35
Sochen Sochen is offline
FRC #3316
Sochen is an unknown quantity at this point
Denso window motors
Hello,
i'm trying to rebuild my team's robot from breakaway (nevermind why) and i can't find exact instructions on how to connect the denso window motors to the power distriution board. I tried googling it but there isn't much info available. It would be greatly appreciated if someone can provide some sort of instructions or point me to a manual.
Unread 11-01-2011, 05:43
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Re: Denso window motors
power dist diagram for 2010
Unread 11-01-2011, 06:33
FRC #3316
Ok thanks for the diagram it helped. But now the question is if i should connect the window motors with a spike to the 30A or with a jaguar to the 40A in the Power Distribution Board.
Unread 11-01-2011, 07:56
Gdeaver Gdeaver is offline
FRC #1640
If you want variable speed on the window motor use a victor not a jag. There is a problem with premature shut down if a jag is used. Also be aware that the window motor has locking pins in the motor to worm gear coupler. These can lock and cause problems. They can Be removed.
Unread 11-01-2011, 07:57
30A are all you need for a window motor.
Use a Spike if you only want full power or off (forward/backward/off)
Use a Jaguar/Victor if you want variable speed, a la joystick fine control. (slow-medium-fast)
Unread 11-01-2011, 15:37
FRC #3316
Thanks for the help got it working
