Go to Post Trust me. I am a Clock after all. ;) - Elgin Clock [more]
Unread 11-01-2011, 16:27
jackforey jackforey is offline
FRC #3717
jackforey is an unknown quantity at this point
Smile I need complete tutorial.
My team has not yet recieved our flash drives and I am the programmer only for the team and i know bnothing about what Im doing. I knowhow to program, but I do not has any of the code or any idea what to do or use. Can someone please tell me how so I can start looking over our base code.
Unread 11-01-2011, 16:32
R2D2DOC's Avatar
R2D2DOC R2D2DOC is offline
AKA: Laszlo Hideg
no team (Judge & Volunteer)
R2D2DOC will become famous soon enoughR2D2DOC will become famous soon enough
Re: I need complete tutorial.
Consider going to white papers section of the forum as well as NI FRC LabView. Navigate to:
http://decibel.ni.com/content/commun...gSet=undefined
Good Luck
Unread 11-01-2011, 16:50
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
What programming language are you using? If you're using Labview I would look at the videos here: http://www.frcmastery.com/ That should help. I learned how to program the robot last year. I also started not knowing what I was doing. I would also recommend looking around Chief Delphi if you are needing instructions on a specific task (such as changing from arcade drive to tank drive). If you need Labview help, you can PM me and I'll see if I can help.
David
Team #2829
Unread 11-01-2011, 17:13
FRC #3717
I want to use c++ because I know tat one.
Unread 11-01-2011, 17:15
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
Start at square 1; the kit of parts page:
http://usfirst.org/roboticsprograms/....aspx?id=18530
Read the Getting Started pdf (and the rest of them as needed), then do the OTB test so you have a working test bed (could take 2 or 3 days; I'm assuming you are on a a rookie team). This will include deciding which programming language you are going to use (LabVIEW, C/C++, or Java), and configuring the cRio and the computer(s) you plan to use for code development and driver stations.
For FRC-specific programming tips check out the CD-Media and the offerings at:
http://thinktank.wpi.edu/Portal
Note there are several generations of control systems represented in these collections; some info in older media will be obsolete.
Finally, when you have tried to follow the manuals a couple of times and its still not working, just post your question here (or in the appropriate sub-forum); keep a tab on your browser open here and check in often. Most likely someone who is slightly ahead of you will have already asked a similar question, and you can learn from their mistakes before you even try something for the first time.
Good luck; this stuff is complex, don't expect it to go perfectly smoothly. Even veterans have to figure the new stuff every year, in addition to re-learning the old stuff.
Unread 11-01-2011, 18:30
josalek josalek is offline
FRC #3360
josalek is an unknown quantity at this point
Where to go to post a Thread
thank you
Unread 11-01-2011, 18:36
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
thank you
http://www.chiefdelphi.com/forums/ne...newthread&f=51
