Go to Post ... hey which end of the robot faces the wall anyways? Oops.... :rolleyes: - dhitchco [more]
  #31   Spotlight this post!
Unread 11-01-2011, 17:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: More than one minibot on robot
Originally Posted by 1631JD View Post
Well we are already going to build at least two minibots for the coopertition points, and if it provides beneficial to have two then why not do it?
Thanks. We'll see if it will work, though the only problem could be accidental damage to the arm. That is the risk though in competitions like this so I guess its no big deal.
I have no response why they would have more than one on the robot. Lets say its for "backup" I mean they know if the bot did not deploy right and they try another bot, even if they make the second deployment, those points would be nullified or even lose more due to penalties
Of course I will convince we need at least 2 mini bots, but not on the robot. The weight and space needed can be utilized more wisely
  #32   Spotlight this post!
Unread 12-01-2011, 02:00
1631JD 1631JD is offline
Psychotron
AKA: Jordan
FRC #1631 (Rockin' Robots)
Team Role: Tactician
1631JD is an unknown quantity at this point
well now that there is the team update we can close this thread
I was in charge of rules and safety until they stopped to think. Now I'm just in charge of rules.
