The FIRST "Where to get more" PDF:
http://usfirst.org/uploadedFiles/Rob...re_1-10-11.pdf
In the PDF, the classmate PC is listed as:
CTL Corp 2GO Classmate PC NBCE11F
www.ctlcorp.com/go/first
Also, R75 permits you to use other computers, so long as the proper driver station software is loaded on them.
<R75> The Driver Station software provided on the FRC website (www.usfirst.org/frc/kitofparts) is the only tool permitted to collate driver/operator inputs and communicate them to the ROBOT. The Driver Station software must be revision 01.05.11.00 or newer.
Teams are permitted use a portable computing device of their choice (laptop computer, PDAs, etc.) to host the Driver Station software while participating in competition MATCHES.
Please note that 19V DC, 2A power will be provided at the PLAYER STATION for Classmates provided in the 2010 and 2011 KOPs via Classmate power adapters. The manufacturer has confimed that the power supply provided at the PLAYER STATION is compatible with both 2010 and 2011 Classmate versions. No 120VAC port will be available.
The FMS will verify that the Driver Station software is correct before it will permit a ROBOT to operate on the FIELD.
