Go to Post Here's my standard for-every-new-member-of-Chief-Delphi-Welcome: WELCOME TO CHIEF DELPHI!!!!!! :D - [more]
Unread 11-01-2011, 18:33
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Diffrences Of The 2009 Camera And 2011?
Anybody know any big diffrences
Unread 11-01-2011, 23:35
Re: Diffrences Of The 2009 Camera And 2011?
The newer camera is fixed focus.
Unread 11-01-2011, 23:39
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: Diffrences Of The 2009 Camera And 2011?
The new one is Shiny
Unread 12-01-2011, 01:13
I believe the Axis site still contains the user manual and other documents about the 206.
The new one is fixed focus, slightly smaller, power and reset are relocated and less likely to be an issue, viewing angle is slightly different, and the new one supports a number of additional compression methods which you likely don't care about.
The vision analysis code can decompress JPG and MJPG, but not MP4 or others. The laptop could with new code or you could build and add your own libs to the cRIO.
Greg McKaskle
Unread 12-01-2011, 01:54
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
An extension of this question: Would there be any problem to run both of these on the same robot at the same time (after of course modifying the AxisCamera class as needed)?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 12-01-2011, 01:59
No problem at all. Out of curiosity, is this for processing on the cRIO, or sending back to dashboard?
Greg McKaskle
Unread 12-01-2011, 02:04
AKA: Ian Thompson
It would be for sending to the dashboard. Right now though it's all just a hypothetical (the head of our driver training is extremely prejudiced against using the camera feed to drive)
Unread 12-01-2011, 10:01
The reason I ask, is, the addition of the switch and some simple MJPG code makes it a much better experience than last year.
I will likely post an example next week that can be incorporated into a custom dashboard. If you want to forge ahead, you can get a reasonable prototype by configuring the cameras to be in the team IP range, plugging them into the switch, and on a laptop on the subnet, open up a browser window viewing a different camera in each.
Greg McKaskle
