Go to Post The horse is dead; stop beating it please. - DonRotolo [more]
Unread 11-01-2011, 10:45
BumbleB3339 BumbleB3339 is offline
FRC #3339
BumbleB3339 is an unknown quantity at this point
Does the MiniBot need to be a "bot"
Does the MiniBot have to be a "Bot" can it just be a block that hits the light and sets it off?
Cause what it really needs to do it hit the button at the top of the pole to set the light off. Does it need all the requirements of a robot can't it just be an object like a computer mouse that sets it off.
Unread 11-01-2011, 11:23
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Does the MiniBot need to be a "bot"
There is a specific definition of MINIBOT, including the parts it must be made out of. It does not have to meet the size/weight requirements for the ROBOT; it has it's own set of rules. See section 4.3.14 of the manual for rules on the MINIBOT and section 1.6 for definitions.
There is currently a debate about whether it is permissible to launch a passive MINIBOT to hit the target, which will hopefully be resolved in a Team Update or Q&A response within a couple of days.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 11-01-2011, 14:29
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
I am pretty sure that the rules say that you must have the minibot attach to the tower below the deployment line. As long as you do not launch the Minibot above the deployment line then you can launch a minibot away from your hostbot.
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 11-01-2011, 14:34
They say it must be deployed below the line. <G20>, <G22>. But the definition of deployment is sufficiently vague to be possibly construed as allowing launching and not contacting the post at all.
However, launching something that is not attached to the pole will be frowned upon under the Safety rules.
P.S. "Pretty sure" doesn't cut it. It is best to cite the rule. For example, last year a team was "pretty sure" that their relief valve could be located off the compressor. The inspector at a preseason said it was good... Then the LRI agreed with me that it wasn't at the official event.
Unread 11-01-2011, 16:03
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
In the manual, it specifies that you need at least ONE battery on the minibot. However, that doesn't mean you have to hook it up to anything.
Unread 11-01-2011, 16:07
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Could you quote that rule please? I can't seem to find it...
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 11-01-2011, 16:08
ATannahill ATannahill is online now
AKA: Alex Tannahill
Please show me where it says you need that.
Prize: 1 cookie.
- Arizona North
Unread 11-01-2011, 16:15
Some folks say <R92> says that.
I say that it doesn't, and I also think the GDC has enough common sense not to force us to use a battery.
But even <R92> bars more than one battery.
Unread 11-01-2011, 16:20
Mongai's Avatar
Indian Guy
AKA: Alec
Prize: 1 cookie.
<R92> The following items are the only permitted materials for use on the MINIBOTS:
C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)
After seeing EricH's post, though, I'm starting to question this statement.
Unread 11-01-2011, 16:26
AKA: Alex Tannahill
I was more refering to the 'at least' part.
- Arizona North
Unread 11-01-2011, 18:56
JuniorGS JuniorGS is offline
FRC #1510 (Wildcats)
JuniorGS is an unknown quantity at this point
I agree that a battery isn't required, it is just stated that the 12v is allowed. According to what I've read, I don't feel that the MiniBot needs to remain atop the tower once the pressure sensors have been triggered.
Unread 11-01-2011, 19:07
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
<R92> begins with: "The following items are the only permitted materials for use on the MINIBOTS:" The list following is only a list of the items that can be used... a team isn't required to use all of them or any specific ones, as long as no unlisted components are used.
This seems like the most reasonable interpretation, I suppose the question should be asked of the GDC, though...
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 11-01-2011, 19:52
I'm >< to calling the GDC politicians instead of geniuses.
From Team Update #1:
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). Violation: The TOWER on which the MINIBOT is DEPLOYED is disabled. If the MINIBOT is not deployed DEPLOYED on something other than a TOWER, then the ALLIANCE’Ss TOWER upon which the highest RACE SCORE was earned will be discounted.[bluebox]<G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel).[/bluebox]
In other words, you must use the FTC battery.
Unread 11-01-2011, 20:08
Goosier's Avatar
Goosier Goosier is offline
FRC #1458
Goosier is an unknown quantity at this point
i just read rule G19. all it says is: "After deployment, minirobots must remain completely autonomous."
Unread 11-01-2011, 20:09
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Sigh. Glad they announced this after FIRST Choice orders could started to be placed.
I highly doubt this was a decision made after 3 days of the game being out.
Ricky Quinones
Director of Sales - VEX Robotics
