Go to Post The events are not just a competition, but a celebration of 6 weeks of hard work. - ChristinaR [more]
Unread 11-01-2011, 20:26
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
Re: Does the MiniBot need to be a "bot"
in update #1 it states that your mine bot has to be attached to the pole so no lanching
Unread 11-01-2011, 20:28
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
Originally Posted by Goosier View Post
i just read rule G19. all it says is: "After deployment, minirobots must remain completely autonomous."
http://www.usfirst.org/uploadedFiles...0Update_01.pdf
"The Few. The Proud. The Skunks."
Unread 11-01-2011, 20:34
Goosier's Avatar
Goosier Goosier is offline
FRC #1458
Goosier is an unknown quantity at this point
i take it back, G19 is exactly what EricH said
Unread 11-01-2011, 20:54
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
BLUEBOX <G19> states that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT.
Then could the minibot somehow trigger a device itself (spring loaded) and shoot itself up to the top of the pole?
2013 Team Co-Captain, Base driver, Head of Design and Manufacturing
2013 Waterloo Regional Finalists
2013 BAE Systems Regional Winners
2012 Arizona Regional Winners
2012 GTR East Regional Finalists
2011 Galileo Division Finalists
2011 Waterloo Regional Finalists
2011 GTR West Regional Finalists
"When in Rome"
Unread 11-01-2011, 20:55
Same Bluebox says something to the effect of you can't store vertical-movement energy in the Minibot, except in the battery.
Unread 11-01-2011, 20:59
biancs15's Avatar
AKA: Austin
FRC #0610 (Coyotes)
Then couldn't the spring be on the bottom of the minibot and a motor powers it downwards. After a certain period of time, the motor stops and a mechanism triggers the spring to release and propel it to the top (with the help of the motors going forward).
Would this be considered as stored energy?
"When in Rome"
Unread 11-01-2011, 21:09
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by StevenB View Post
There is a specific definition of MINIBOT, including the parts it must be made out of.
Is permitted to be made of, not "must".
Originally Posted by JuniorGS View Post
According to what I've read, I don't feel that the MiniBot needs to remain atop the tower once the pressure sensors have been triggered.
It doesn't matter what you feel. Sorry to be harsh, but inaccurate information on ChiefDelphi is far more damaging than NO information.
In other words, you must use the FTC battery.
Only if you expect your minibot to use any energy! If you're fine with it sitting at the bottom of the pole after deployment, then no battery is required.
Unread 11-01-2011, 21:15
Dr Fritz's Avatar
Dr Fritz Dr Fritz is offline
AKA: Fritzelin
FRC #1165 (Team Paridise)
Dr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura about
Exclamation Re: Does the MiniBot need to be a "bot"
ok to anyone who may be thinking about using springs please read <R92>
it will save you time later :/
ph.D Asskickanomics
Magnets work well
Thor Protector of Man kind
Raise your swords up high
See the black birds fly
Let them hear your rage
Show no fear
"Our Mini-bot goes 'clink-whee"
